[Mapguide-trac] [mapguide-trac] #2896: Fix correctness of "batch sorted block" feature join algorithm
trac_mapguide at osgeo.org
Mon Nov 2 19:58:58 PST 2026
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: low | Milestone: 4.0.1
Component: Feature Service | Version:
Severity: trivial | Keywords:
External ID: |
The following tickets were "fixed" by #1888
https://trac.osgeo.org/mapguide/ticket/502
https://trac.osgeo.org/mapguide/ticket/791
https://trac.osgeo.org/mapguide/ticket/1396
https://trac.osgeo.org/mapguide/ticket/1790
All the above tickets used the "batch sorted block" feature join
algorithm, and #1888 fixed their sort capabilities to avoid using this
algorithm. There were many correctness issues with this algorithm, which
#1888 swept under the rug by using a more optimal algorithm.
The original "batch sorted block" algorithm still has correctness issues.
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2896>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
