[Mapguide-trac] [mapguide-trac] #2900: Map Agent loose ends
trac_mapguide at osgeo.org
Thu Nov 5 06:55:18 PST 2026
Reporter: jng | Owner: jng
Type: defect | Status: assigned
Priority: low | Milestone: 4.0.1
Component: Map Agent | Version:
Severity: trivial | Keywords:
External ID: |
## GETSPATIALCONTEXTS
`ACTIVEONLY` should not be a required parameter (and default to `0` if not
specified)
## SELECTAGGREGATES
When `FORMAT=application/json` the response is not a literal XML to JSON
conversion
XML:
```xml
<?xml version="1.0"
encoding="UTF-8"?><PropertySet><PropertyDefinitions><PropertyDefinition><Name>total</Name><Type>int64</Type></PropertyDefinition></PropertyDefinitions><Properties><PropertyCollection><Property><Name>total</Name><Value>9</Value></Property></PropertyCollection></Properties></PropertySet>
JSON:
```json
"PropertySet": {
"PropertyDefinitions": [
"PropertyDefinition": [
"Name": [
"total"
"Type": [
"int64"
"Properties": [
"Name": [
"total"
"Type": [
"int64"
# GEO.*
`FORMAT` parameter checking should be case-insensitive
Bad/invalid `FORMAT` parameters not being checked
# GETMAPIMAGE
Validate required `FORMAT` parameter (ie. Throw if missing)
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2900>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
