[Mapguide-trac] [mapguide-trac] #2901: Security sweep
trac_mapguide at osgeo.org
Fri Nov 13 03:09:13 PST 2026
Reporter: jng | Owner: jng
Type: task | Status: closed
Priority: high | Milestone: 4.0.1
Component: General | Version:
Severity: critical | Resolution: fixed
Keywords: | External ID:
Changes (by jng):
* resolution: => fixed
* status: assigned => closed
Comment:
In [changeset:"10288" 10288]:
{{{#!CommitTicketReference repository="" revision="10288"
#2901: Fix the buffer overflows and input-validation gaps a security sweep
found
A read-through of Common, Server, Web and Portable (no Oem, no third party
code) found eleven
defects - two critical, three high, four medium, two low - and a pattern
behind most of them:
sprintf into a fixed stack buffer, where the size of the destination and
the length of the result
were two unrelated facts maintained by hand at every call site.
Make that pattern impossible to write at those call sites.
MgUtil::FormatBuffer is a variadic
template over char (&)[N]: the buffer's size is deduced from the argument,
so a call cannot pass a
size that is not the buffer's own and cannot be given a pointer at all,
and it formats with
vsnprintf, truncating and always NUL-terminating, returning the length the
format would have
produced. It carries __attribute__((format(printf, 2, 3))) on GCC and
Clang, so -Wformat now checks
every call. That check is not decoration: it is what found four further
mismatches that were
already there, listed below.
98 call sites in 26 files were rewritten: 62 to MgUtil::FormatBuffer, 28
to snprintf in the
libraries that do not link Foundation (Common/MdfParser/IOUtil.cpp and the
MG renderers
DWFRenderer, KmlRenderer and ObservationMesh), and the two %lf tolerance
fields in
SpatialContextData to MgUtil::DoubleToString, where a 128-byte buffer
could not hold the value
being described in the first place.
The findings:
- External entity and DTD resolution was on for every document the server
parses, so a map or
symbol definition could make the server read a local file or fetch a URL
on its behalf.
setLoadExternalDTD(false) and setDisableDefaultEntityResolution(true)
are now set by
Common/Foundation/System/XmlUtil.cpp, Common/MdfParser/SAX2Parser.cpp,
Common/MdfParser/FSDSAX2Parser.cpp and
Portable/MgPortable/Services/ResourceService.cpp.
- Common/Renderers/AGGImageIO.cpp sized two stack allocations from the
image width and height and
allocated them before checking anything. The row-pointer table and the
per-row RGB buffer are
`height` pointers and `width` pixels, so both are now bounded by
MG_MAX_PNG_DIMENSION (65536,
512 KB and 192 KB respectively) and checked before either allocation.
- Three services turned a client- or definition-supplied number into a
size without asking whether
it could be one. Server/src/Services/Kml/ServerKmlService.cpp rejects a
DPI that is zero,
negative, not finite or above 10000 (ValidateDpi), and GetScale rejects
a viewport of zero area.
Server/src/Services/Tile/ServerTileService.cpp rejects a metatile factor
outside the range the
providers' fixed arrays can express (ValidateMetaTileFactor), and
TileCacheDefaultProvider.cpp
and TileCacheXYZProvider.cpp clamp the loop bound they iterate to.
Server/src/Services/Rendering/
ServerRenderingService.cpp applies the same check to both entry points
that take the metatile
factor the client sends.
- Common/Foundation/Data/Byte.cpp copied numRead bytes without relating
numRead to the length left
in the destination; the copy, the position and the remaining length are
now checked together.
- The multipart request parser in
Web/src/MapAgentCommon/MapAgentCommon.cpp scanned for the end of
a part without bounding the scan to the request, and compared the end
tag with a length that was
not the tag's; the scan is bounded and the comparison is a memcmp.
Web/src/IsapiAgent/
IsapiPostParser.cpp allocated its buffer with room for a terminator but
only wrote one on some
content-type paths, leaving the multipart parser to run past the request
as a C string; it is now
terminated for every content type.
- Server/src/Common/Manager/LogManager.cpp took the two names RenameLog
works with as file names
inside the log directory and passed them to it unfiltered, so either
could name a path elsewhere;
a separator in either is rejected.
- The PHP, ASP.NET and JSP viewers passed a help page name from the query
string straight to the
filesystem. Web/src/mapviewerphp/{common,gettingstarted}.php,
Web/src/mapviewernet/{common,gettingstarted}.aspx and
Web/src/mapviewerjava/{common,gettingstarted}.jsp now validate the name
against a page-name
pattern and confirm the resolved path stays inside the localized help
directory.
What the format attribute found, all of it pre-existing:
- Web/src/ApacheAgent/ApacheResponseHandler.cpp and
Web/src/IsapiAgent/IsapiResponseHandler.cpp
formatted a size_t Content-Length with %d, so the header reported the
low 32 bits; the three
sites now cast to INT32 like the outLen handling beside them.
- Common/PlatformBase/Data/Int32Property.cpp read an INT32 with "%li" on
the Linux branch, which
reads eight bytes from a four-byte argument; it is "%d" now.
- Common/Foundation/System/Util.cpp formatted an INT64 with "%lli", which
is a long on LP64; it is
"%lld" after a (long long) cast.
Two further defects the tests turned up rather than the review:
- MgUtil::TrimEndingZeros (both overloads) treated an integer string as if
it had a fractional part
and dropped its last digit: "100" came back as "1". Both now only trim
when there is a '.'.
- MgUtil::SingleToString and DoubleToString are used for the identity
properties' string form in
Common/PlatformBase/MapLayer/SelectionBase.cpp instead of a fixed-buffer
%f, which both truncates
and is locale dependent - an identity value is compared and stored, so
it must be neither.
Tests:
- Server/src/UnitTesting/TestMisc.cpp: FormatBuffer (bounds, truncation,
terminator),
ByteReadBounds, XmlExternalEntityRejected, IntegerToStringBounds,
FloatingPointToStringBounds and
StringToNumberBounds, the last three covering every MgUtil conversion at
its boundaries
(INT32/INT64 limits, the 2^53 integer precision limit of the double
path, denormals, 1e308, and
the TrimEndingZeros cases above).
- Server/src/UnitTesting/TestLogManager.cpp: three RenameLog traversal
assertions.
- Server/src/UnitTesting/TestKmlService.cpp and TestTileService.cpp:
GetLayerKmlRejectsInvalidDpi
and InvalidMetaTileFactorRejected.
- Server/src/UnitTesting/TestServerAdminService.cpp: GetDocument read a
document only a later case
creates, so it passed or failed by order; it now writes the document,
reads it back and checks
the content.
- Server/src/UnitTesting/TestRenderingService.cpp:
RenderAreaSymbolClipping asserted on the pixels
of a symbol <Text> primitive, which the renderer drops entirely when the
font engine resolves no
font, so the case failed for a reason unrelated to clipping on a machine
with no configured font
directory. Its second primitive is a <Path> now.
Verified in both configurations against this change set: Debug (ASan/LSan)
`mgserver test all`
passes 658 cases / 49,777 assertions with no leak records and no
AddressSanitizer summary, and
Release `mgserver test all` passes 659 cases / 49,782 assertions. The
three suites carrying the new
cases (Misc, LogManager, KmlService, TileService, ServerAdminService,
RenderingService) were also
run one process each, which is where exit-time races differ from the
aggregate.
Fixes #2901
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2901#comment:1>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
