[Mapguide-trac] [mapguide-trac] #2196: TimedEventHandler Errors on Windows 7 Home Premium
trac_mapguide at osgeo.org
Fri Oct 23 14:47:21 PDT 2026
Reporter: cgountanis | Owner: (none)
Type: defect | Status: closed
Priority: high | Milestone: 4.0
Component: General | Version: 2.4.0
Severity: trivial | Resolution: fixed
Keywords: installer, mapguide, programdata | External ID:
Changes (by jng):
* resolution: => fixed
* status: new => closed
Old description:
> 41 posts
> This post was updated on Dec 03, 2012; 9:48am.
> I am having issues with Windows 7 Home Premium on a tablet. Tried MG0S
> 2.2 and 2.4 64bit. IIS is working, PHP is working, everything seems to be
> installed properly. MapAgent fails and the MapGuide IIS Worker Crash
> happens everytime when doing a repo list (Default screen in MapAgent).
> I logged in as Administrator and everything seems to install just fine.
> I tried switching from fastcgi to the MapAgent.exe on .fcgi calls and got
> a could not find C:\ProgramData\Autodesk cord system files. I copied
> those over from another machine and I still get IIS Worker crashes over
> and over.
> Is it possible to install on Windows 7 Home Premium, some kind of tablet
> as well as the folders in Explorer have check boxes. I am telling you
> though, everything seems like it should work, installers are not giving
> errors, php.info works, IIS is working... really at a loss here.
> I checked every setting, seems like the installer is not doing things
> like installing the AUtodesk folder in C:\ProgramData\Autodesk... is this
> normal?
> Here is the base of the information and initial post: http://osgeo-
> org.1560.n6.nabble.com/Windows-7-Home-Premium-MapGuide-2-2-and-2-4
> -Testing-td5020395.html
New description:
I am having issues with Windows 7 Home Premium on a tablet. Tried MG0S 2.2
a could not find C:\ProgramData\Autodesk cord system files. I copied those
over from another machine and I still get IIS Worker crashes over and
over.
I checked every setting, seems like the installer is not doing things like
normal?
Comment:
Fixed r10219
Ticket URL: <https://trac.osgeo.org/mapguide/ticket/2196#comment:4>
MapGuide Open Source <http://mapguide.osgeo.org/>
MapGuide Open Source Internals
More information about the mapguide-trac
