[mapguide-users] Windows Operating System
Andy Morsell
amorsell at spatialgis.com
Tue Apr 4 20:18:44 EDT 2006
The only problem with this is if you want to use the .NET web extensions.
The available Apache .NET module does not fully support .NET 2.0 and the
MapGuide API. You can partially get around the IIS simultaneous connection
issue by editing the Windows metabase. I have done this and have not had
any issues developing MGOS applications on XP Pro (but our production server
is a server OS). Details on this are in a document I wrote for MapServer
Enterprise installs. Much of this document does not apply anymore with the
release of MGOS 1.0, but this particular section, the very last one in the
document, still does apply. It can be downloaded from
http://www.spatialgis.com/mse_install_tips.pdf
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Sent: Tuesday, April 04, 2006 2:27 PM
Subject: RE: [mapguide-users] Windows Operating System
Also if you do use XP, then Apache is the preferred Web server. Apache
supports an unlimited number of simultaneous connections, while IIS on XP
only supports two. If you want to use IIS then you should install MapGuide
on a server OS.
Walt
_____
Sent: Tuesday, April 04, 2006 5:20 PM
Molly,
MapGuide is a server application and should be run on a Server Class
operating system, ie: Windows 2000 and Windows 2003.
However, it does work on Windows XP, but is not Officially supported. For
demo purposes in house we have setup MapGuide server and Studio on a Windows
XP machine, but again this is not officially supported. For any real
applications you should be using a Server Class operating system.
Bruce
_____
From: Molly Thompson [mailto:molly_t42 at yahoo.com]
Sent: Tuesday, April 04, 2006 3:05 PM
Subject: [mapguide-users] Windows Operating System
Hello All,
Does Mapguide Server work on windows XP Professional?
As mentioned in the requirements, it works only on Windows NT 2003 and
Windows 2000.
But it is not specified in the Installation guide
(https://mapguide.osgeo.org/docs/InstallConfigureMapGuideOnWindows.pdf) that
what operating system should be used?
Regards,
Molly Thompson
_____
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great
<http://us.rd.yahoo.com/mail_us/taglines/postman7/*http:/us.rd.yahoo.com/evt
=39666/*http:/beta.messenger.yahoo.com> rates starting at 1¢/min.
_____
How
=39666/*http:/beta.messenger.yahoo.com> low will we go? Check out Yahoo!
Messengers low PC-to-Phone
<http://us.rd.yahoo.com/mail_us/taglines/postman8/*http:/us.rd.yahoo.com/evt
=39663/*http:/voice.yahoo.com> call rates.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060404/cca660f6/attachment.html
More information about the Mapguide-users
