[mapguide-users] MapGuide Studio Preview Window
Steven J Reed sjreed at edcomputing.com
Wed Apr 5 16:55:52 EDT 2006
Alain,
I am using IIS on Windows XP Pro.
Within Studio, I open any of the Samples/Sheboygan/Layouts, click Refresh in
the Web Preview pane and all I see is text.  (Not sure where I'm supposed to
see 'Go').
I can, however, view any and all of the samples via
http://localhost/Mapguide/dotnetviewersample/dwfviewersample.aspx or
http://localhost/Mapguide/phpviewersample/dwfviewersample.php.
.Steve
  _____
From: Alain Lebatard [mailto:alain.lebatard at autodesk.com]
Sent: Wednesday, April 05, 2006 1:23 PM
Subject: RE: [mapguide-users] MapGuide Studio Preview Window
Steven,
If you have an existing web layout in your repository, open it with Studio's
web layout editor, and click 'Go' to preview the web layout within a web
browser. If this is working then there is probably just a problem with the
configuration of the aliases "mapviewerajax" and "mapviewerdwf" that Studio
use for the preview window.
However If you see the same problem in the web browser as in the preview
window, then your web server is not properly configured to handle pages with
a php extension (or jsp or aspx depending on what you are using), which
causes these pages to be returned as text instead of being executed. Tell us
also if you are using Apache or IIS, and if you are using PHP, JSP or
ASP.NET.
Alain
  _____
From: Steven J Reed [mailto:sjreed at edcomputing.com]
Sent: Wednesday, April 05, 2006 12:47 PM
Any suggestions as to why it doesn't????
  _____
From: Bill Dhimitri [mailto:bill.dhimitri at autodesk.com]
Sent: Wednesday, April 05, 2006 12:41 PM
Yes.  It should work.
  _____
Sent: Monday, April 03, 2006 5:05 PM
Subject: [mapguide-users] MapGuide Studio Preview Window
Is this supposed to be working?  Mine just shows html source, not any of the
resources that are defined.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060405/c44f5229/attachment.html
More information about the Mapguide-users mailing list
