[mapguide-users] How can I connect to my server with a WMS connection??
Thomas M. Tuerke thomas.m.tuerke at autodesk.com
Mon Apr 10 14:37:48 EDT 2006
I’m inclined to think that there’s something else going on.  Not having any data sources published should only cause the WFS Capabilities document to list zero feature types; the same holds true for layers and WMS.
RE: [mapguide-users] How can I connect to my server with a WMS connection??
It seems i can connect, but i get a XML error.. To what URL do I connect? How does this work, is there any info on setting this up?
Just following up… do you happen to have (or remember) the XML error in question?
- Thomas
  _____
Sent: Monday, April 10, 2006 1:46 AM
Subject: SV: [mapguide-users] How can I connect to my server with a WMS connection??
You must make your data "published" to the WFS.
Go to your Data-catalog in Studio. Right-click and choose "Properties". In the Service Properties tab you check the box "Public via Web Feature Service". An earlier bug was that you needed to fill in something in the "Keyword"s textfield.
If you already have done this and you still get an error, i dont know what the problem might be.
/Tommy
  _____
Från: Willem Schwarte [mailto:willem at giskit.nl]
Skickat: den 10 april 2006 10:17
Till: users at mapguide.osgeo.org
Ämne: RE: [mapguide-users] How can I connect to my server with a WMS connection??
And what about WFS?
Changing the service type in URL below, results in an error.
  _____
Van: Bill Dhimitri [mailto:bill.dhimitri at autodesk.com]
Verzonden: vrijdag 7 april 2006 15:46
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] How can I connect to my server with a WMS connection??
Willem,
If you installed the Sheboygan sample data, then you can try this.  Enter this URL into your web browser (replacing the “localhost” with your server name if necessary):
http://localhost/mapguide/mapagent/mapagent.fcgi?SERVICE=WMS&VERSION=1.0.0&REQUEST=GetCapabilities
Bill
  _____
Sent: Friday, April 07, 2006 8:36 AM
Subject: [mapguide-users] How can I connect to my server with a WMS connection??
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060410/436c3dd8/attachment.html
More information about the Mapguide-users mailing list
