the lost log file
"Antonio Lucas Rodríguez (sr&tec)"
alucas at srtec.com
Tue Apr 11 12:26:30 EDT 2006
Sorry, my mail server has blocked the attached file... I paste the
content here:
API_NAME: LoadPackage
STATUS_CODE: Failed
PACKAGE_NAME: Sheboygan.mgp
PACKAGE_DESC: Created by ShpLoadProcedure.Execute().
PACKAGE_DATE: 2006-04-11T17:03:07
PACKAGE_SIZE: 6281275
USER_NAME: Administrator
SERVER_NAME: srv1.SrTec.local
SERVER_ADDR: 192.168.0.3
START_TIME: 2006-04-11T17:03:17.53125
END_TIME: 2006-04-11T17:03:19.5
OPS_FAILED: 1
OPS_RECEIVED: 5
AVRG_OP_TIME: 0,0004921875
ERROR_MESSAGE: Argument is null.
STACK_TRACE: - MgLibraryRepositoryManager.LoadResourcePackage line
176 file
c:\build_tux_area\mgdev\server\src\services\resource\LibraryRepositoryManager.cpp
- MgResourcePackageLoader.Start line 150 file
c:\build_tux_area\mgdev\server\src\services\resource\ResourcePackageLoader.cpp
- MgResourcePackageLoader.PerformOperation line 228 file
- MgResourcePackageLoader.SetResource line 308 file
- MgRepositoryManager.SetResource line 818 file
c:\build_tux_area\mgdev\server\src\services\resource\RepositoryManager.cpp
- MgRepositoryManager.AddResource line 791 file
- MgResourceContentManager.AddResource line 153 file
c:\build_tux_area\mgdev\server\src\services\resource\ResourceContentManager.cpp
OP_DETAILS:
<2006-04-11T17:03:18.109375>
DeleteResource(Library://Samples/Data/lctras.FeatureSource)
SetResource(Library://Samples/Data/lctras.FeatureSource,Op1_SETRESOURCE_CONTENT.xml,Op1_SETRESOURCE_HEADER.xml)
<2006-04-11T17:03:18.171875>
SetResourceData(Library://Samples/Data/lctras.FeatureSource,lctras.sdf,File,Op2_SETRESOURCEDATA_DATA)
<2006-04-11T17:03:19.484375>
DeleteResource(Library://Samples/Layers/lctras.LayerDefinition)
SetResource(Library://Samples/Layers/lctras.LayerDefinition,Op4_SETRESOURCE_CONTENT.xml,)
Antonio Lucas
Software Engineer
alucas at srtec.com <mailto:alucas at srtec.com> www.srtec.com
<http://www.srtec.com>
963·959·513
Fax 963·731·756
SER&TEC
avda. Ausias March 79 - 1
46013 Valencia
More information about the Mapguide-users
