[mapguide-users] ODBC problem...
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue Apr 11 13:55:34 EDT 2006
Yes. It is an Access 2000 Database.
Andrew
Robert Fortin wrote:
> Andrew,
> Was it done against an Access db?
> RF
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Tuesday, April 11, 2006 12:57 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] ODBC problem...
> I got this:
> An exception occurred in FDO component. RDBMS: No current open
> database.
> database. Exception occurred in method MgFdoConnectionManager.Open at
> line 912 in file
> c:\build_tux_area\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> Andrew
> Joel Carranza wrote:
>> Well, the first time I tried this, I got a short reply of "False" and
>> then the MapGuide service crashed. Nothing reported in any of the
>> error logs. Restarted and ran again.
>> I got the following:
>> An exception occurred in FDO component. Bad parameter to method.
>> Exception occurred in method MgFdoConnectionManager.Open at line 912
>> in file
>> Any ideas?
>> --Joel
>> *From:* Tom Fukushima [mailto:tom.fukushima at autodesk.com]
>> *Sent:* Tuesday, April 11, 2006 9:31 AM
>> *Subject:* RE: [mapguide-users] ODBC problem...
>> Hi Andrew,
>> The diagnostic information that shows up in the test connection
>> information area is not very useful (this problem has been fixed
>> recently but is not in Studio 16802). Please try the following:
>> 1) Open your browser to the HTML index of MapGuide web tier. It has
>> the form: http://<servername>/mapguide/mapagent/index.html
>> <http://%3Cservername%3E/mapguide/mapagent/index.html>. (Message
>> https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=321
>> <https://mapguide.osgeo.org/servlets/ReadMsg?listName=users&msgNo=321> also
>> has information on how to get to these pages.)
>> 2) Click on the Feature Service API link in the top left frame.
>> 3) Click on the TestConnection link in the bottom left frame.
>> 4) In the Resource ID field, type in the name of the ODBC feature
>> source that you created. This should have the form
>> Library://<path>/<name>.FeatureSource.
>> 5) Press Submit
>> The resultant web page should give information on why the connection
>> is not working.
>> Hope this helps,
>> Tom
>> *From:* Joel Carranza [mailto:jec at gatekeeper.com]
>> *Sent:* Tuesday, April 11, 2006 10:29 AM
>> I don't think that the project is just with Jet connections. I have
>> been unable to get any kind of ODBC (access, Oracle ODBC) connection
>> to work, resulting in an identical error. I get similar results using
>> either the Data Source Name or Connection String options
>> Joel Carranza
>> Gatekeeper Systems
>> Andrew DeMerchant wrote:
>>> I've just installed the latest Mapguide, Mapserver, and Studio as
>>> well as the ODBC and Raster providers. Everything working fine,
>>> except the ODBC. I've got a Jet connection set up on my computer,
>>> and the provider does find it...I select the data source name, save
>>> the connection, and then try "Test Connection" and get some errors:
>>> System.Net.WebException: The remote server returned an error: (559)
>>> MgFdoException.
>>> at
>>> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.ExecutePendingGetRequestToString(Operation
>>> operation)
>>> at
>>> Autodesk.MapGuide.Studio.Site.Comm.RequestManager.TestConnection(String
>>> resourceId, String provider, String connectionString)
>>> at Autodesk.MapGuide.Studio.Site.FeatureSourceInfo.TestConnection()
>>> at
>>> Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.TestConnectionControl.buttonTestConnection_Click(Object
>>> sender, EventArgs e)
>>> Am I missing something here, or does it just not yet work with Jet
>>> databases? My data source is totally fine, as it works with other
>>> web apps that I have made.
>>> Andrew
>>> ps - Great work on the Raster provider!
>>> *Andrew DeMerchant*
>>> *Computer Technologist*
>>> ph.506-453-1025
>>> fax 506-453-9470
>>> /GEMTEC Limited <http://www.gemtec.ca>
>>> /191 Doak Road
>>> Fredericton, NB, Canada
>>> E3C 2E6
> *Andrew DeMerchant*
> ph.506-453-1025
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
*Andrew DeMerchant*
ph.506-453-1025
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users
