[mapguide-users] problem with setresource
Paul Spencer
pspencer at dmsolutions.ca
Thu Apr 13 18:03:45 EDT 2006
Jason, good idea ... I thought that was possibly the problem but
unfortunately this doesn't seem to change it at all :(
Cheers
Paul
On 13-Apr-06, at 2:01 PM, Jason Birch wrote:
> Are you sure it isn't the magic_quotes_gpc setting in PHP? I think
> you
> can turn this off in your script with ini_set?
> Jason
> -----Original Message-----
> From: Paul Spencer [mailto:pspencer at dmsolutions.ca]
> Sent: Thursday, April 13, 2006 11:00
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] problem with setresource
> I'm not sure what to do with this. I am calling the MapAgent
> SETRESOURCE operation through a proxy script (PHP). The content of
> the
> resource is passed as a string to the proxy script which then adds the
> appropriate multipart form information to get MapGuide to accept the
> resource content. This works (once I figured out that it requires a
> file name). However, if the proxy script is on a machine with Apache
> 1.3, the XML content gets quotes in the xml escaped so you end up with
> tags like
> <tag attr=\"test\"/>
> which causes MapGuide server to fail to load the content.
> The same proxy running on Apache 2.0 works without problem (because it
> doesn't escape the quotes).
> Is this a problem with MapGuide server (i.e. should it be unescaping
> quotes)? Is this a bug in some Apache versions? Should I not worry
> about it and make it a requirement for my app to run under Apache 2.x?
> Cheers
> Paul
> |Paul Spencer pspencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
