[mapguide-users] Troubles accessing subversion with guest user
Traian Stanev traian.stanev at autodesk.com
Tue Apr 18 08:24:36 EDT 2006
You're right, it doesn't work for me as guest either. However, it works
fine if you log in as a regular user, so you can do that as a workaround
for now.
Traian
-----Original Message-----
From: Sylvain Pasche [mailto:sylvain.pasche at camptocamp.com]
Sent: Tuesday, April 18, 2006 6:33 AM
Subject: [mapguide-users] Troubles accessing subversion with guest user
I'm trying to access the subversion repository following the
documentation on https://mapguide.osgeo.org/servlets/ProjectSource. But
I can't access the repository using username "guest" and empty password.
I've got a "permission denied", even if I try in a web browser with URL
https://mapguide.osgeo.org/svn/mapguide/trunk
Has anyone managed to successfully access the subversion repository
using the guest account ?
Best regards,
Sylvain
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
