[mapguide-users] RE: ODBC problem...
Butler, Juan P
jpbutler at co.pinellas.fl.us
Wed Apr 19 12:05:24 EDT 2006
I can create the join, but like Andy says, nothing comes out of it. I
go to set up the join between the two columns and when I try and pull up
the layer, nothing. If I choose a fields that are not related, the
graphics appear, but no tooltip from the Access database. So I can't
use any database data as of now, correct?
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Tuesday, April 18, 2006 8:22 PM
Subject: RE: [mapguide-users] RE: ODBC problem...
Here are the steps I took to create the join. Note that I wasn't able
to do with anything with the join in terms of creating a layer from it,
however.
* Once your datasource is setup and you can see the tables listed
in the Refine Data Setup area, click the New Extended Feature Class
button.
* Choose your other datasource in the repository that you are
connecting to
* Choose the Primary Feature class (table)
* Click on your New Join below the Extension you just created
* You will most likely only have one option for the Secondary
class (table)
* Select your Primary Column and Secondary Column fields. These
are the key fields tying together your primary (tabular) and secondary
(spatial) datasources.
If you get this far, please let us know if you can successfully create a
layer where you can view the resultant objects. I also tried creating a
layer from X and Y points in a table from this database and, again, was
not able to view the resultant geometry.
Andy Morsell
-----Original Message-----
From: Thud732 [mailto:devlin.fung at sapience360.com
<mailto:devlin.fung at sapience360.com> ]
Sent: Tuesday, April 18, 2006 4:30 PM
Subject: [mapguide-users] RE: ODBC problem...
Hi Andy:
Can you please outline your 'join connection' steps? I was able to
establish a successful test connection, but failed when joining.
Thank you.
TC
View this message in context:
http://www.nabble.com/Failed-to-test-the-Web-Server-Extensions-after-ins
tallation-t1432431.html#a3978903
<http://www.nabble.com/Failed-to-test-the-Web-Server-Extensions-after-in
stallation-t1432431.html#a3978903>
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060419/e0fa781b/attachment.html
More information about the Mapguide-users
