[mapguide-users] Access database - Studio 2007 preview
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Apr 21 15:45:21 EDT 2006
Ok, I've got the one from myfeedback installed now....still the same
problem. Which suggests that there's something else going on here. My
datasource works fine, because I'm using it in other vbscript webpages.
There's got to be something that I'm missing here.....could it have
anything to do with Studio needing some special ntfs permissions?
Andrew
Butler, Juan P wrote:
> Access 2000.
> Did you download it from the myfeedback site?  If not, try downloading
> it from there.
> - Juan
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Friday, April 21, 2006 12:36 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Access database - Studio 2007 preview
> Sounds like the same version I'm using....what type of database was yours?
> Andrew
> I'm using version 1.0.0.16802.   Mapguide Studio 2007.
> I downloaded it from the http://myfeedback.autodesk.com/ site.
> - Juan
> *From:* Andy Morsell [mailto:amorsell at spatialgis.com]
> *Sent:* Friday, April 21, 2006 12:25 PM
> *To:* users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
> *Subject:* RE: [mapguide-users] Access database - Studio 2007 preview
> That was me using the Studio beta version rather than preview.  Juan,
> I know you got this working, are you using the preview version of
> Studio downloaded from the public web site?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> *Sent:* Friday, April 21, 2006 9:20 AM
> I'm referring to one that I posted about maybe a week ago.....I can't
> get any ODBC datasource to actually work in Studio....I see the
> datasources fine, but never see a list of table / fields, and when I
> test my connection, it fails. The concensus seemed to be that it was
> the Studio Preview, because someone else did the exact same steps, and
> it worked....the only difference was our Studio versions (his was the
> full).
> Andrew
> Andrew,
> Which ODBC problem are you referring to?   The two issues that I
> brought up yesterday were the highlighting of a selection doesn't work
> on a joined layer and the refresh issue.   Are these what you are
> referring to?
> - Juan
> *Sent:* Friday, April 21, 2006 9:45 AM
> *Subject:* [mapguide-users] Access database - Studio 2007 preview
> I'm using Studio 2007 (preview) v1.0.0.16802.....Is the ODBC problem
> to do with this version of Studio, or the OSGeo FDO Provider for ODBC?
> I've got a project that I need to get done in 1 month, and am trying
> to figure out if it's going to happen or not. With my current setup, I
> can't get any of my Access ODBC datasources to work....no one has
> suggested a workaround as of yet, so I'm starting to think that it's
> just not going to happen. Does the solution have to come from Autodesk
> (a new Studio version), or OSGeo (a new Provider? I would tend to
> think that Autodesk would be slower than OSGeo, so that's why I'm
> wondering.....Thanks.
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.506-453-1025
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> *Andrew DeMerchant*
> ph.506-453-1025
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
> *Andrew DeMerchant*
> ph.506-453-1025
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
ph.506-453-1025
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
