[mapguide-users] problems with invoke URL
    sukalyan chakraborty
    chakraborty.sarkar at gmail.com
    Sat Apr 22 01:06:12 EDT 2006
yes i'm using mapguide 6.5
when i attempt to run it from
http://localhost/mapguide/mapviewernet/ajaxviewerabout.aspx then get the
error
 *Compilation Error* *Description: *An error occurred during the compilation
of a resource required to service this request. Please review the following
specific error details and modify your source code appropriately.
*Compiler Error Message: *CS0246: The type or namespace name 'OSGeo' could
not be found (are you missing a using directive or an assembly reference?)
*Source Error:*
   Line 21: <%@ Import Namespace="System.Web" %>
Line 22: <%@ Import Namespace="System.Globalization" %>Line 23: <%@
Import Namespace="OSGeo.MapGuide" %>Line 24:
Line 25: <!-- #Include File="common.aspx -->
*Source File:* C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\ajaxviewerabout.aspx
   *Line:* 23
On 4/21/06, Butler, Juan P <jpbutler at co.pinellas.fl.us> wrote:
>  Are you using Mapguide 6.5?   Not sure why you would be posting here for
> .mwf file.   The new Mapguide Open Source no longer uses this format.
> If you are using Mapguide 6.5, just use Mapguide Author.
> Juan Butler - Senior Programmer/Analyst
> GIS Applications
> Pinellas County Information Systems
> jpbutler at pinellascounty.org
> *From:* sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
> *Sent:* Friday, April 21, 2006 6:57 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] problems with invoke URL
> can u tell me please how can i create the .mwf file?
> On 4/20/06, *shailesh* <shailesh at simplexindia.com> wrote:
> hi all.
> i have a problem with invoke url command, when i assign the URL TO OPEN
> ..\dotnetviewersample\navigatetask.aspx
> it shows me page cannot be dispalyed
> however when i type
> http:\\localhost\mapguide\dotnetviewersample\navigatetask.aspx
> in URL TO OPEN it works
> i also tried something like c:\1.html after creating a file in C:\ even
> that does not work
> and also when i tested my application whihc is on the webserver
> it tried typing the URL to invoke
> http:\\myipaddress\mapguide\dotnetviewersample\navigatetask.aspx i was
> unable to get
> (i tried this because the localhost path was working onmy local machine)
> need help on the correct way to write the URL to Invoke "
> thanks
> --------------------------------------------------------------------- To
> unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
> commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060422/83a30f54/attachment.html
More information about the Mapguide-users
