[mapguide-users] problems with invoke URL
Andy Morsell
amorsell at spatialgis.com
Mon Apr 24 00:41:33 EDT 2006
I just wanted to mention that there doesn't seem to be any conflicts between
running MapGuide 6.5 and MapGuide Open Source. I run both on more than one
computer and have not had any problems related to the side by side installs.
Andy
_____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Saturday, April 22, 2006 12:55 PM
Subject: RE: [mapguide-users] problems with invoke URL
I think you are confused. We are testing Mapguide Open Source which is a
totally different version than Mapguide 6.x. You should put the new
version of Open Source on a machine that doesn't have previous versions of
Mapguide. You will need to download Mapguide Studio for your "map
authoring" and data loads.
Also, the .NET version of the Open Source install requires .NET framework
2.0. This is the reson for your error.
- Juan
_____
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
Sent: Sat 4/22/2006 1:06 AM
Subject: Re: [mapguide-users] problems with invoke URL
yes i'm using mapguide 6.5
when i attempt to run it from
http://localhost/mapguide/mapviewernet/ajaxviewerabout.aspx then get the
error
Compilation Error
Description: An error occurred during the compilation of a resource required
to service this request. Please review the following specific error details
and modify your source code appropriately.
Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could not
be found (are you missing a using directive or an assembly reference?)
Source Error:
Line 21: <%@ Import Namespace="System.Web" %>
Line 22: <%@ Import Namespace="System.Globalization" %>
Line 23: <%@ Import Namespace="OSGeo.MapGuide" %>
Line 24:
Line 25: <!-- #Include File="common.aspx -->
Source File: C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\ajaxviewerabou
t.aspx Line: 23
On 4/21/06, Butler, Juan P <jpbutler at co.pinellas.fl.us> wrote:
Are you using Mapguide 6.5? Not sure why you would be posting here for
.mwf file. The new Mapguide Open Source no longer uses this format.
If you are using Mapguide 6.5, just use Mapguide Author.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
_____
From: sukalyan chakraborty [mailto: chakraborty.sarkar at gmail.com]
Sent: Friday, April 21, 2006 6:57 AM
can u tell me please how can i create the .mwf file?
On 4/20/06, shailesh < <mailto:shailesh at simplexindia.com>
shailesh at simplexindia.com> wrote:
hi all.
i have a problem with invoke url command, when i assign the URL TO OPEN
..\dotnetviewersample\navigatetask.aspx
it shows me page cannot be dispalyed
however when i type
http:\\localhost\mapguide\dotnetviewersample\navigatetask.aspx
in URL TO OPEN it works
i also tried something like c:\1.html after creating a file in C:\ even that
does not work
and also when i tested my application whihc is on the webserver
it tried typing the URL to invoke
http:\\myipaddress\mapguide\dotnetviewersample\navigatetask.aspx i was
unable to get
(i tried this because the localhost path was working onmy local machine)
need help on the correct way to write the URL to Invoke "
thanks
--------------------------------------------------------------------- To
unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
commands, e-mail: users-help at mapguide.osgeo.org
<mailto:users-help at mapguide.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060423/76f294e1/attachment.html
More information about the Mapguide-users
