[mapguide-users] continuing problems installing MapGuide OS on Suse10
Traian Stanev traian.stanev at autodesk.com
Mon Apr 24 08:27:52 EDT 2006
Yes, we've seen that hang -- it happens during initial initialization of
xalan library when fdo is first loaded. We only got that when using gcc
4.0.0 on Fedora -- which gcc are you using? The only thing I can
recommend for now is to recompile mapguide with gcc 4.0.2...
Traian
-----Original Message-----
From: joanne cook [mailto:j.cook at oxfordarch.co.uk]
Sent: Monday, April 24, 2006 6:34 AM
Subject: [mapguide-users] continuing problems installing MapGuide OS on
Suse10
Hi List
I have been struggling with compiling and installing MapGuide OpenSource
on Suse10 for about three weeks now. After chasing down a lot of errors
and problems (mostly with the previous release of the code) I now get
all the way through the compilation and installation of the newest
general release with no obvious errors. However, when I start the
server, it hangs. I have followed the instructions for using gdb, and
the attached screenshot shows the output from the stack trace. I would
be very grateful if someone could give me a pointer as to where my
problems lie, or rather how to interpret the results of the stack trace!
Many thanks
Jo Cook
Joanne Cook BSc MLitt AIFA
Information Systems Coordinator
Oxford Archaeology North
This message has been scanned for viruses by BlackSpider MailControl -
www.blackspider.com
More information about the Mapguide-users mailing list
