Problems with selection II
Amit Stein
amitstein at gmail.com
Mon Apr 24 14:03:31 EDT 2006
I had a problem similar to Juan's.
I selected the feature using the Web API, which was working well. But when I
joined this feautre with Database connection, the following error appeared:
The specified object was not found.The specified object was not found.
Exception occurred in method GetItem at line 115 in file
c:\build_tux_area\mgdev\common\service\data\NamedCollection.cpp
Amit
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060424/c4278e8c/attachment.html
More information about the Mapguide-users
