[mapguide-users] Any work being done on fixing MS IE KB912945
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Apr 26 17:22:31 EDT 2006
The artifact is included in the release notes:
https://www.osgeo.org/files/documents/12/71/releasenotes.html
<https://www.osgeo.org/files/documents/12/71/releasenotes.html>
DWF Viewer 7 will be available soon.  Autodesk has a Beta you can sign
up for (http://myfeedback.autodesk.com/) if you want to see a preview.
  _____
Sent: Wednesday, April 26, 2006 4:03 PM
Subject: RE: [mapguide-users] Any work being done on fixing MS IE
KB912945
Whoops.
Yeah, I looked for it and couldnt find it. Can you give me an Artifact
ID?
Is there a release date for the next version of the DWF Viewer?
--Joel
  _____
From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Sent: Wednesday, April 26, 2006 12:48 PM
KB912945
It's already been fixed in MapGuide.  There was an artifact (you can
search for it :->).
The next release of DWF Viewer will also address this.
Walt
  _____
Sent: Wednesday, April 26, 2006 3:46 PM
Subject: [mapguide-users] Any work being done on fixing MS IE KB912945
Microsoft has deployed a "security" patch which forces you to "click to
activate" any ActiveX control before you can use it. It is exceptionally
annoying. Naturally, this affects the DWF Viewer.  It also affects the
legend and property pane.  If you havent already dealt with it, you can
see info about it here
http://www.microsoft.com/technet/security/advisory/912945.mspx
<http://www.microsoft.com/technet/security/advisory/912945.mspx> . It is
also worth looking at http://support.microsoft.com/kb/912945
<http://support.microsoft.com/kb/912945>
Has anyone looked at implementing the workaround? Can someone log this
as an artifact?
--Joel
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060426/adf689e5/attachment.html
More information about the Mapguide-users mailing list
