[mapguide-users] Can I get a clue?
Willem Schwarte
willem at giskit.nl
Thu Apr 27 05:11:17 EDT 2006
This also happens to me a lot. Refreshing the site loads the page with
correct images.
But I don't know why this is happening. For customers and users
accessing the site it is not good. I know that if this happens to our
clients they will complain about this very much.
Is there any suggestion or solution how to avoid this? Or why it is
happening at all?
Willem
Van: Andy Morsell [mailto:amorsell at spatialgis.com]
Verzonden: donderdag 27 april 2006 5:54
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] Can I get a clue?
If you hit the refresh button in your browser, does it load up without
the question marks? I see the same thing about 1 out of 5 times when
accessing my site and refreshing the page usually forces it to load. If
you view a web layout from Studio, will it load? Or is this only
happening with the sample application?
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Sent: Wednesday, April 26, 2006 8:06 PM
Subject: [mapguide-users] Can I get a clue?
Ok, I'm stumped, I can run
http://localhost/mapguide/dotnetviewersample/ajaxviewersample.aspx
And see the sample application but each of the layers has a "?" and
doesn't display anything in the map display area.
The admin page showed my sample data package was loaded.. ie I was
able to load the package without error.. Logs look ok.
However Studio will not get passed the default login page, no matter
what I put in, it will not connect to the site.. I followed the getting
started guide and even reinstalled this, the odd part is it worked on a
different PC for me.
W2003 IIS6.
Any ideas, I have another ASP.Net application in a different application
pool running well on the same PC. I followed the the install guide word
4 word but no luck.
Bill
Bill at PoconoGIS.com
www.PoconoGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060427/7d86e79b/attachment.html
More information about the Mapguide-users
