[mapguide-users] Base Layers that are based on Oracle Spatial data
Traian Stanev traian.stanev at autodesk.com
Wed Aug 2 19:42:26 EDT 2006
As far as I understand it, only changes to the layer or map definitions will be detected. For example change in the styling for the layer. Changes to the actual data in Oracle will not be detected.
Traian
	-----Original Message-----
	From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
	Sent: Wed 8/2/2006 5:36 PM
	Cc:
	Subject: RE: [mapguide-users] Base Layers that are based on Oracle Spatial data
	Well, I’ve been told that Enterprise handles the changes to data that is stored in the repositories.  From my understanding, data that is changed in the repositories will be marked in someway so that the tiles can be rebuilt as needed.    Can someone from Autodesk please clarify this?
	Juan Butler - Senior Programmer/Analyst
	GIS Applications
	Pinellas County Information Systems
	jpbutler at pinellascounty.org
	Please note: All mail sent to and from Pinellas County Government is subject to the Public Records Law of Florida.
  _____
	From: Andy Morsell [mailto:amorsell at spatialgis.com]
	Sent: Wednesday, August 02, 2006 5:30 PM
	My understanding of the current functionality of base layers is that they don't update themselves based on an underlying data change regardless of the source data type.  This would be up to you to delete the images from your TileCache directory to force them to rebuild the next time somebody viewed that map area.
	Andy Morsell, P.E.
	Spatial Integrators, Inc.
	http://www.SpatialGIS.com
  _____
	Sent: Wednesday, August 02, 2006 2:02 PM
	Subject: [mapguide-users] Base Layers that are based on Oracle Spatial data
	Does anyone at Autodesk (or anyone that has tested it already) know if I use Oracle Spatial data for my base layers, will Mapguide Enterprise know about the changes and update the tiles accordingly?   I’m in the process of testing this and just wanted to know if anyone has had any experience with it.
	Thanks.
	GIS Applications
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060802/6767e82c/attachment.html
More information about the Mapguide-users mailing list
