[mapguide-users] Base Layers that are based on Oracle Spatial data
Jason Birch
Jason.Birch at nanaimo.ca
Wed Aug 2 22:12:17 EDT 2006
It would be useful to set a property on the layer like InvalidateDate that would force tile-replacement for tiles that are older than that date. If this feature was available, it would be possible to set up a trigger in Oracle to invalidate the tile cache for affected layers. I'd prefer this method to just deleting the cache, because of the huge file IO caused by the delete, and because it would reduce fragmentation of the volume. This would be usable by other external processes, such as daily SDF updates via FME, etc...
Jason
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Wed 2006-08-02 4:42 PM
To: users at mapguide.osgeo.org; users at mapguide.osgeo.org
Subject: RE: [mapguide-users] Base Layers that are based on Oracle Spatial data
As far as I understand it, only changes to the layer or map definitions will be detected. For example change in the styling for the layer. Changes to the actual data in Oracle will not be detected.
Traian
-----Original Message-----
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Wed 8/2/2006 5:36 PM
Cc:
Well, I've been told that Enterprise handles the changes to data that is stored in the repositories. From my understanding, data that is changed in the repositories will be marked in someway so that the tiles can be rebuilt as needed. Can someone from Autodesk please clarify this?
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
Please note: All mail sent to and from Pinellas County Government is subject to the Public Records Law of Florida.
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, August 02, 2006 5:30 PM
My understanding of the current functionality of base layers is that they don't update themselves based on an underlying data change regardless of the source data type. This would be up to you to delete the images from your TileCache directory to force them to rebuild the next time somebody viewed that map area.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Sent: Wednesday, August 02, 2006 2:02 PM
Subject: [mapguide-users] Base Layers that are based on Oracle Spatial data
Does anyone at Autodesk (or anyone that has tested it already) know if I use Oracle Spatial data for my base layers, will Mapguide Enterprise know about the changes and update the tiles accordingly? I'm in the process of testing this and just wanted to know if anyone has had any experience with it.
Thanks.
GIS Applications
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060802/d6756c3e/attachment.bin
More information about the Mapguide-users
