[mapguide-users] Join Features
farzad ghavam
ghavam at ehealth.ir
Thu Aug 3 02:45:12 EDT 2006
thanks Dave,
I can view the data by new feature class and create a web layout, but
now I can't select any polygon of this layer for view that properties.
also sometimes in dwf viewer this layer hasn't any data,do you know
why?(just DWF, AJAX is right)
farzad.
> In the layer you must change your feature class to the new one
defined
> in the join. You should then see the property list change to show the
> additional columns.
> Leave the geometry as the orginal geometry property for the SDF. If
you
> select the new geometry you will get nothing.
> Dave
> _____
> From: Farzad Ghavam [mailto:farzadghavam at yahoo.co.uk]
> Sent: Wednesday, August 02, 2006 7:02 AM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] Join Features
> Hi to all,
> I'm sorry for my english,
> I have a problem with Join Feature section by following steps:
> 1-Load a SDF file and create a layer by this ( Named : WorldSDF )
> 2-create a new connection with ODBC-Table in an Access DB file (
> Named : WorldDB ) and get 'Successful connection' message after test
> connection.
> 3-in 'Join with other feature sources(optional)' create a new
> extended feature class and connect 'WorldSDF' and 'WorldDB' by those
> fileds.
> 4-create a layer by new feature class ( NewLayer ) but when
preview
> ,there isn't any data
> please help me.
> thanks
> farzad
More information about the Mapguide-users
