[mapguide-users] Base Layers that are based on Oracle Spatial data
Traian Stanev traian.stanev at autodesk.com
Thu Aug 3 09:07:32 EDT 2006
Yes, I imagine there is a point at which base layers make more sense in,
like you say, high levels of usage.
  _____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, August 02, 2006 11:19 PM
Subject: RE: [mapguide-users] Base Layers that are based on Oracle
Spatial data
I don't have much experience with tile caching and the new MapGuide, but
if the data is only being updated once per day or once every few days,
and you have high levels of usage on your web app, I'd have to believe
that you would get some kind of performance return from only having to
render those layers when they are actually modified...  Hmm.  I think
that was a run-on-sentence.
Jason
  _____
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Wed 2006-08-02 8:10 PM
Spatial data
If the layer will be changing a lot, is there any point for it to be a
base layer at all? Just make it a regular dynamic layer...
	-----Original Message-----
	Sent: Wed 8/2/2006 10:12 PM
	Cc:
Oracle Spatial data
	It would be useful to set a property on the layer like
InvalidateDate that would force tile-replacement for tiles that are
older than that date.  If this feature was available, it would be
possible to set up a trigger in Oracle to invalidate the tile cache for
affected layers.  I'd prefer this method to just deleting the cache,
because of the huge file IO caused by the delete, and because it would
reduce fragmentation of the volume.  This would be usable by other
external processes, such as daily SDF updates via FME, etc...
	Jason
  _____
	Sent: Wed 2006-08-02 4:42 PM
	To: users at mapguide.osgeo.org; users at mapguide.osgeo.org
Oracle Spatial data
	As far as I understand it, only changes to the layer or map
definitions will be detected. For example change in the styling for the
layer. Changes to the actual data in Oracle will not be detected.
	Traian
		From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
		Sent: Wed 8/2/2006 5:36 PM
		Cc:
		Well, I've been told that Enterprise handles the changes
to data that is stored in the repositories.  From my understanding, data
that is changed in the repositories will be marked in someway so that
the tiles can be rebuilt as needed.    Can someone from Autodesk please
clarify this?
		Juan Butler - Senior Programmer/Analyst
		GIS Applications
		Pinellas County Information Systems
		jpbutler at pinellascounty.org
		Please note: All mail sent to and from Pinellas County
Government is subject to the Public Records Law of Florida.
  _____
		From: Andy Morsell [mailto:amorsell at spatialgis.com]
		Sent: Wednesday, August 02, 2006 5:30 PM
		My understanding of the current functionality of base
layers is that they don't update themselves based on an underlying data
change regardless of the source data type.  This would be up to you to
delete the images from your TileCache directory to force them to rebuild
the next time somebody viewed that map area.
		Andy Morsell, P.E.
		Spatial Integrators, Inc.
		http://www.SpatialGIS.com
  _____
		Sent: Wednesday, August 02, 2006 2:02 PM
		Subject: [mapguide-users] Base Layers that are based on
Oracle Spatial data
		Does anyone at Autodesk (or anyone that has tested it
already) know if I use Oracle Spatial data for my base layers, will
Mapguide Enterprise know about the changes and update the tiles
accordingly?   I'm in the process of testing this and just wanted to
know if anyone has had any experience with it.
		Thanks.
		GIS Applications
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060803/25e6c1f1/attachment.html
More information about the Mapguide-users mailing list
