Error with loading shp in MG studio
Swati Prabhu swatip at bonair.stanford.edu
Thu Aug 3 18:40:20 EDT 2006
Thanks for the response. I did check it and no other application is
accessing the file. I have MG studio installed on the test server itself
and other than the Map server no other application is running. That system
does have Autocad installed on it...
Content-Type: text/plain;
         charset="us-ascii"
Date: Thu, 3 Aug 2006 15:23:30 -0700
Subject: [mapguide-users] Error with loading shp in MG studio
The only case where I have seen that problem is when another application
has the shp files locked.  Is it possible that this is the case?
Jason
Swati Prabhu,
Facilities Operations - Maps and Records
Stanford University
Phone: 650 723 0988 Fax: 650 723 7095
More information about the Mapguide-users mailing list
