[mapguide-users] OGR with postgis support
kenny at keniginc.com
Mon Aug 14 08:38:58 EDT 2006
Thanks very much, Kenneth!
I got it now.
Just one related question. Are we still unable to connect to sql
server db using ODBC?
Quoting "Kenneth, GEOGRAF A/S" <ks at geograf.dk>:
> There is an FDO folder for Studio in C:\Program
> Files\Autodesk\MapGuideStudio2007\FDO.
> There is an FDO folder for MgServer in C:\Program
> Files\Autodesk\MapGuideEnterprise2007\Server\Bin\FDO.
> Correct the above paths to your system.
> You must copy the OGRProvider.dll to both folders above, and edit the
> providers.xml in both folders.
> If you use MapGuide OS, it has recently shifted to FDO 3.2, and you
> have to change the version number in providers.xml.
> If you use MapGuide EP, you must build OGR provider, using an older FDO
> snapshot, otherwise it won't load.
> After restarting the service and studio, you should be able to select
> New -> Data connection...
> On the list you should now see "OSGeo FDO Provider for OGR"
> I hope you are working on windows, as you will have to compile a
> .dll/.so for both windows and linux otherwise.
> Mvh. Kenneth, GEOGRAF A/S
> kenny at keniginc.com skrev:
>> Hi Kenneth and thank you for responding to this thread.
>> How do you edit the providers.xml?
>> It is my understanding that from the readme associated with the ogr
>> provider that I downloaded that you need to do 2 things:
>> 1, add an entry, this entry:
>> <FeatureProvider>
>> <Name>OSGeo.OGR.0.1</Name>
>> <DisplayName>FDO Provider for OGR</DisplayName>
>> <Description>Access to OGR data sources</Description>
>> <IsManaged>False</IsManaged>
>> <Version>0.1.0.0</Version>
>> <FeatureDataObjectsVersion>3.1.0.0</FeatureDataObjectsVersion>
>> <LibraryPath>OGRProvider.dll</LibraryPath>
>> </FeatureProvider>
>> to providers.xml and as you correctly stated, add the OGRprover.dll
>> into FDO.
>> I have done these and restarted the mapGuide service.
>> If all goes well, when you go to Studio and attempt to add a
>> database connection, you should the OGR provider. Right now, I only
>> see the ODBC connection that I set up awhile back.
>> Did I miss something?
>>> You must edit providers.xml and copy the dll into the FDO directory.
>>> This must be done in both the Service FDO folder and the Studio FDO folder.
>>> I'm guessing that Studio uses the GUI part, and the Service does the
>>> actual data access.
>>> Perhaps Studio should be modified to load this from the server?
>>> But then there would be windows/linux problems.
>>> I don't know how this works in Web Studio, if thats what you are trying.
>>>> Ok,
>>>> I know I have been a bit slower catching on to this than most,
>>>> largely because other extreme commitments but please bear with me.
>>>> I just downloaded, unzipped and compiled OGR Provider with
>>>> PostGIS support so I can gain direct access to some of our files
>>>> using connections.
>>>> After adding an entry to providers.xml, I restarted service, wen
>>>> to studio and database connection but it isn't there.
>>>> What am I doing wrong?
>>>> Thanks very much in advance
>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
