[mapguide-users] ODBC - Successful connection - FINALLY!!!!!!
Ivan Miličević ivan at ineo.hr
Fri Aug 18 06:01:28 EDT 2006
Here is my files! It's wokring now!!!
Here is the list of locale Ids:
http://www.microsoft.com/globaldev/reference/winxp/xp-lcid.mspx
Hope it helps!
RENAME reg.txt to reg.bat and put both files in "c:\"
-----Original Message-----
Sent: Thursday, August 17, 2006 9:18 AM
Subject: RE: [mapguide-users] ODBC - Successful connection - FINALLY!!!!!!
Can you send me Unattend.txt that you created for your country?
From: Le Ingenieur Inconnu [mailto:gg at odyssey.com.uy]
Sent: 16. kolovoz 2006 20:52
Subject: Re: [mapguide-users] ODBC - Successful connection - FINALLY!!!!!!
Hello!
We have run into a similar problem while running MGE in a Spanish Windows
version. Yesterday Melkor found out that the MapGuideServer guess the
localization settings from the user that runs the process. As a first
approach we changed the user that runs the process to one that has a US
locale. Having this changed, MapGuide Studio starts to work correctly with
the default Data Editor.
If you wish to change the locale of the System account on a non-english
Windows, here is an article that talks on how to do it.
http://support.microsoft.com/default.aspx?scid=kb;en-us;289125
 Regards,
gg.
View this message in context:
http://www.nabble.com/ODBC---Successful-connection---FINALLY%21%21%21%21%21%
21-tf2026417.html#a5838330
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
[RegionalSettings]
   LanguageGroup=1
   Language=0409
   SystemLocale=0409
   UserLocale=0409
   InputLocale=0409:00000409
   UserLocale_DefaultUser=0409
   InputLocale_DefaultUser=0409:00000409
   MUILanguage=0409
   MUILanguage_DefaultUser=0409
@echo off
title Configuring keyboardlayout
rundll32.exe shell32,Control_RunDLL intl.cpl,,/f:"c:\regopts.txt"
exit
More information about the Mapguide-users mailing list
