[mapguide-users] BC Albers Projection
Bruce Dechant bruce.dechant at autodesk.com
Fri Aug 18 16:07:10 EDT 2006
Joy,
I assume you are talking about wanting to add the projection to the list
that appears in Studio. Unfortunately, Studio uses a commercial
coordinate system library that has no easy way to update it. The
MapGuide Enterprise server uses this same commercial coordinate system
library. However, the open source MapGuide server uses PROJ4 and so you
could add it to the server easily. The problem is that the list shown by
Studio does not come from the server and so you would not be able to
select it.
Bruce
-----Original Message-----
Sent: August 18, 2006 12:46 PM
Subject: [mapguide-users] BC Albers Projection
I am trying to define BC Albers in MapGuide Open Source, or Enterprise.
 I have the projection perameters (thanks to Kori Maleski):
# British Columbia Albers Standard Projection
> <9822> +proj=aea +lat_1=50.0 +lat_2=58.5 +lat_0=45.0 +lon_0=-126.0
> +x_0=1000000.0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs  <>
Where do I go from here and how do I get BC Albers to appear in the
projections options when importing data?
Thanks,
Joy Appler
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
