[mapguide-users] Pre-generating and populating the TileCache
Walt Welton-Lair
walt.welton-lair at autodesk.com
Sun Aug 20 20:12:37 EDT 2006
The TileService has a GetTile API. All you need to do is write a script which calls GetTile for all the tiles you're interested in, and those tiles will be placed in the cache.
Walt
-----Original Message-----
From: Srikanth Nadhamuni [mailto:srikanth at egovernments.org]
Sent: Sat 8/19/2006 9:48 AM
Cc:
Subject: [mapguide-users] Pre-generating and populating the TileCache
We would like to pre-generate tiles at various zoom levels (MapLayerGroup) and pre-populate the TileCache (Program Files/MapGuideOpenSource/Server/Repositories/TileCache) so as to improve performance of map rendering on the browser (to give the end-user google like interactivity for pan and zoom operations).
The TileService does not seem to have any APIs for tile creation, but the RenderingService has a RenderTile function:
virtual MgByteReader <file:///C:\Program%20Files\MapGuideOpenSource\WebServerExtensions\Help\d8\d50\class_mg_byte_reader.html> * RenderTile <file:///C:\Program%20Files\MapGuideOpenSource\WebServerExtensions\Help\de\dbd\class_mg_rendering_service_568e4437f486cf2b7095039695662b69.html#568e4437f486cf2b7095039695662b69> (MgMap <file:///C:\Program%20Files\MapGuideOpenSource\WebServerExtensions\Help\da\df8\class_mg_map.html> *map, CREFSTRING baseMapLayerGroupName, INT32 tileColumn, INT32 tileRow)=0 Returns the specified base map tile for the given map. If a cached tile image exists it will return it, otherwise the tile is rendered and added to the cache.
Has anybody created a program using the above function to pre-populate the cache?
Regards,
-Srikanth
Technology for Social Change
Srikanth Nadhamuni
Managing Trustee
www.egovernments.org <http://www.egovernments.org/>
eGovernments Foundation
303 Ashok Terrace, 2nd Floor, 100 ft Road, Indiranagar Bangalore 560 038
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060820/0db905b2/attachment.bin
More information about the Mapguide-users
