problem in joind feature
farzad ghavam
ghavam at ehealth.ir
Sat Aug 26 04:22:59 EDT 2006
Hi to all,
I have the some problem, please help me.
I do the following steps in my map in the MapGuide Studio:
1.I create an odbc data connection (access database)
2.load a sdf file and at the bottom of this page in "Join with other
feature sources", create a secondry join with that odbc data
connection.
3.I create a layer by this resource(set the data resource in
liberary and set the feature class and geometry)
4.When I use in "Filter applied to data" by sdf properties it is
correct and work very good, but when I use a filed of table(this field
is in table on odbc connection) it is not work.
br ,
farzad
More information about the Mapguide-users
