[mapguide-users] Logs on Linux? Server constantly stops ..
Willem Schwarte
willem at giskit.nl
Mon Aug 28 05:15:05 EDT 2006
I removed the layer and then readded the layer, now it Works fine...
I think it has to do with the fact that at first I had a size of 4
kilometers, which killed the daemon. Maybe there should be a warning
message in studio when stylizing a point with a very large size.
Van: Willem Schwarte [mailto:willem at giskit.nl]
Verzonden: maandag 28 augustus 2006 10:51
Aan: users at mapguide.osgeo.org
Onderwerp: [mapguide-users] Logs on Linux? Server constantly stops ..
Urgentie: Hoog
When I add a specific layer to my map, the daemon is killed. This is a
simple point layer, which uses the same data as another layer. Could
this be the problem of the kills?
Is there some sort of log where I can see what killed the daemon
?Something like Microsofts Event Viewer?
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060828/3dbb6cc0/attachment.html
More information about the Mapguide-users
