Insertation (reference) point of symbols
IBB Ingenieurbüro Battefeld ibb.scigalla at arcor.de
Mon Aug 28 08:26:58 EDT 2006
all symbols has offset. It means, in the original drawing (dwg) the base
point of each block (a simple circle) is the center point. But in the
viewer each symbol seems to has an offset. The change of the reference
point in MapGuide Studio is without effect. It's the same if I use dwg-
or shp-format.
What could be wrong?
Thanks in advance - Peter
P.s.: I'm using MapGuide Server 1.0.1.17812 and MapGuide Studio 1.0.0.17804
More information about the Mapguide-users mailing list
