[mapguide-users] Weird Error when restarting server on Linux
Dave Wilson dave.wilson at autodesk.com
Mon Aug 28 10:26:58 EDT 2006
This appears to be linux specific behaviour in regards to releasing the
port. It takes about 15 seconds before the port is released and the
process will restart.
Dave
  _____
Sent: Monday, August 28, 2006 3:47 AM
Subject: [mapguide-users] Weird Error when restarting server on Linux
So the server is sometimes killed. Sometimes when I try restarting the
daemon, It gives the message that the server is running as daemon. But
when I check with PS -A |grep mgserver there is nothing!?
Now I check the error.log in the server logs directory and there is a
new entry that says:
> Error: Port 2801 is not available, please try using a different port.
> Exception occurred in method MgServer.svc at line 932 in file
Server.cpp
> StackTrace:    Port 2801 is not available, please try using a
different port.
Server.cpp
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060828/114e3057/attachment.html
More information about the Mapguide-users mailing list
