[mapguide-users] Insertation (reference) point of symbols
Ing. Cristian Galdini galdini at dek.it
Tue Aug 29 11:39:33 EDT 2006
Tanks,
but my experience is that
different setting of decimal point  ( , or . )
has not resolved the problem
cristian
Tom Fukushima wrote:
> Hi,
> I've traced this problem down to systems where a "," is used as the decimal point. We should have fixes submitted for this shortly.
> In the meantime the techniques used in this thread http://www.nabble.com/ODBC---Successful-connection---FINALLY%21%21%21%21%21%21-tf2026417.html might also solve this problem.
> Regards
> Tom
> -----Original Message-----
> From: Willem Schwarte [mailto:willem at giskit.nl]
> Sent: Tuesday, August 29, 2006 8:04 AM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] Insertation (reference) point of symbols
> I've had this problem too on Windows. On Linux everything is perfect aligned!
> -----Oorspronkelijk bericht-----
> Van: Ing. Cristian Galdini [mailto:galdini at dek.it]
> Verzonden: dinsdag 29 augustus 2006 9:45
> Aan: users at mapguide.osgeo.org
> Onderwerp: Re: [mapguide-users] Insertation (reference) point of symbols
> Hi, i have the same problem,
> In my case, the server works fine as an application instead as a service (!)
> from prompt "mgserver /interactive"
> IBB Ingenieurbüro Battefeld wrote:
>> Hi,
>> all symbols has offset. It means, in the original drawing (dwg) the
>> base point of each block (a simple circle) is the center point. But in
>> the viewer each symbol seems to has an offset. The change of the
>> reference point in MapGuide Studio is without effect. It's the same if
>> I use dwg- or shp-format.
>> What could be wrong?
>> Thanks in advance - Peter
>> P.s.: I'm using MapGuide Server 1.0.1.17812 and MapGuide Studio
>> 1.0.0.17804
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060829/a3696d86/attachment.html
More information about the Mapguide-users mailing list
