Raster features are not shown
Mindaugas Bliūdžius mindaugas at infoera.lt
Thu Aug 31 03:11:49 EDT 2006
I‘m having similar problem to this topic „rasters, always rasters!“. When i
try to see raster in Studio or elsewhere i get this in error.log:
Error: An exception occurred in FDO component.
        Failed to de-serialize the spatial contexts from the configuration.
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
c:\build_tux_area\mgdev\server\src\services\feature\FeatureServiceHandler.cp
p
  - MgOpDescribeSchemaAsXml.Execute line 110 file
c:\build_tux_area\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cp
p
  - MgServerDescribeSchema.DescribeSchema line 493 file
c:\build_tux_area\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
  - MgServerDescribeSchema.ExecuteDescribeSchema line 189 file
  - MgFdoConnectionManager.Open line 221 file
c:\build_tux_area\mgdev\server\src\common\manager\FdoConnectionManager.cpp
I launched http://localhost/mapguide/mapagent/index.html and tried
DescribeSchema method of Feature Service API. And i get the same error. I
called method leaving „Schema“ textbox empty, maybe there must be entered
something? . Any ideas?
I‘m using Windows Server 2003 Enterprice Edition Service Pack 1 (not R2).
Installed web extension using IIS and .NET as programming language (and
later used typical installation option). I‘m having the same problem with
MapGuide Enterprise 2007 and with MapGuide Open Source 1.0.1.
Mindaugas Bliūdžius
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060831/ffff51d1/attachment.html
More information about the Mapguide-users mailing list
