[mapguide-users] tuning mapguide performance
Chris Gountanis cgountanis at mpower-tech.com
Wed Dec 13 09:38:17 EST 2006
My guess would be to setup solid servers on a solid connection and run
support servers. That would give you a cluster of servers that should
balance the requests I would assume.
Chris
Making complex information more accessible.
-----Original Message-----
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Wednesday, December 13, 2006 8:14 AM
Subject: RE: [mapguide-users] tuning mapguide performance
Why does the server die? Even if it is overloaded, it should just get really
unresponsive, but not die. Is there some sort of exception that is thrown?
Check the logs. 1000 requests for 10 minutes doesn't sound that heavy unless
the requests are doing something really time-consuming.
Traian
Sent: Wednesday, December 13, 2006 12:53 AM
Subject: [mapguide-users] tuning mapguide performance
Hi all,
is there a way to improve the mapguide performance?
As i have try to access to the map and perform some search address
function by simulating 1000 users are accessing in 10 minutes, the
mapguide server die. So I need to keep restarting so that users can
access the map.
I was wondering how to improve the performance as there might me more
than 100000 users will access the map.
Thank you
Regards,
Kencana
View this message in context:
http://www.nabble.com/tuning-mapguide-performance-tf2812176.html#a784757
5
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
