[mapguide-users] Finding list of Mapdefinitions
Scott Reisdorf
reisdorf1 at llnl.gov
Wed Dec 13 15:57:14 EST 2006
You are using the wrong toString(). Use the UpperCase ToString() not
the toString()
-scott
Chris Gountanis wrote:
> When I do:
> MgByteReader byteReader =
> resourceService.EnumerateResources(resId,-1,MgResourceType.MapDefinition);
> String xml = byteReader.ToString();
> All I get in the string is a value of
> "org.osgeo.mapguide.MgByteReader at b0fa61". Any ideas on why?
> Chris
> *From:* Dave Wilson [mailto:dave.wilson at autodesk.com]
> *Sent:* Tuesday, December 12, 2006 5:21 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* RE: [mapguide-users] Finding list of Mapdefinitions
> Thanks Scott. Beat me to it.
> With the DOM parser you can search on the <ResourceId> tag and parse
> the name of the map, here's an example value:
> <ResourceId>Library://QE_Data/Maps/SDF2.0_Dublin_CA83IIIF.MapDefinition</ResourceId>
> By the way it's Library://
> // and not \\ just in case you missed that too.
> Dave
> *From:* Scott Reisdorf [mailto:reisdorf1 at llnl.gov]
> *Sent:* Tuesday, December 12, 2006 4:18 PM
> *Subject:* Re: [mapguide-users] Finding list of Mapdefinitions
> In Java you can do something like this, creating a
> ByteArrayOutputStream and then displaying that stream back as a String.
> ByteArrayOutputStream bos = new ByteArrayOutputStream();
> byte[] byteBuffer = new byte[1024];
> int numBytes = byteReader.Read(byteBuffer, 1024);
> while(numBytes > 0)
> bos.write(byteBuffer, 0, numBytes);
> System.out.println(bos.toByteArray());
> or you can get straight XML back from the MgByteReader, and then parse
> that:
> // ...parse the xml via the DOM
> hope this helps
> -scott
> Scott Hameister wrote:
>> Did that, but I get an MgByteReader object with no clue how to
>> iterate...isn't there a count/getitem method I could use or do I have
>> to convert to a string and Parse or something?
>> *Sent:* Tuesday, December 12, 2006 4:54 PM
>> Try MapDefinition
>> Case sensitive.
>> *From:* Scott Hameister [mailto:ScottH at mPower-tech.com]
>> *Sent:* Tuesday, December 12, 2006 3:53 PM
>> *Subject:* [mapguide-users] Finding list of Mapdefinitions
>> Pulling my Hair out I'm just trying to get a list of Mapdefinitions
>> in the Library:\\
>> I tried doing EnumerateResources on Library\\: with -1 and
>> Mapdefinition, but can't find an API way to get the names....Am I way
>> off target here?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061213/9e5aa052/attachment.html
More information about the Mapguide-users
