[mapguide-users] RE: Please help me
farzad ghavam
ghavam at ehealth.ir
Thu Dec 14 02:23:15 EST 2006
Hi Rouni,
thank you for guide,
but when I want create a data connection ,In this page I haven't any
item named "Define Data Setup", so I cann't select the tables,I
attached to you a picture of this Page .
thanks,
farzad
> Hi Farzad,
> Here's the steps I used to successfully create a layer from either
the
> CityLimit table or the SubCityLimit table from your Access
database. I
> am also attaching some screenshots for your reference.
> 1. Create an ODBC datasource for the database via
> Start->Settings->Control Panel->Administrative Tools->Data Sources
> (ODBC). Click the System DSN tab. 2. Click the Add button. Select
> Microsoft Access driver. Click Finish.
> 3. Enter a name for the datasource, and click Select button to pick
the
> .mdb file. Click OK.
> 4. Start MapGuide Studio and connect to a site.
> 5. Click File->New->Data Connection.
> 6. Select OSGeo FDO Provider for ODBC.
> 7. Choose the Data Source Name radio button and click on the "..."
> button to select the datasource you created in step 3.
> 8. Under the Refine Data Setup, Click the Show Tables button.
Click on
> the Geometry checkbox CityLimit and SubCityLimity. The X and Y
Columns
> should be automatically populate with CityLat and CityLon.
> 9. Save the datasource. You should now be able to use this feature
> source to define a new layer. Select the table (Feature Class) to
use
> (either Default:CityLimit or Default:SubCityLimit), and you should
see
> the cities geometries displayed in the layer preview.
> Ronnie
> -----Original Message-----
> From: farzad ghavam [mailto:ghavam at ehealth.ir]
> Sent: Monday, December 11, 2006 10:38 PM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] RE: Please help me
> Hi Ronnie,
> please find attachments.
> Thanks
> Farzad.
> > Farzad,
> > My email client (Microsoft Outlook) blocks attachments with .mdb
> > extension for security reasons. Can you rename your file to a
> different
> > extension and resend it please?
> > Thanks
> > Ronnie
> > Sent: Friday, December 08, 2006 11:28 PM
> > Subject: Re: [mapguide-users] RE: Please help me
> > Hi Ronnie,
> > Thanks for reply, My .mdb file has 3 tables and I try by 1 table
but
> > not worked,Now I send .mdb file and two pictures of my project,
> > I don't know What do I do?
> > Farzad.
> > > Hi Farzad,
> > > Do you mind sending me your Access database file? In the
> meantime,
> > Is
> > > there more than one table in the database? If yes, maybe you
> could
> > try
> > > modifying your .mdb a bit such that it only contains one table
and
> > let
> > > me know what happens.
> > > Ronnie
> > > From: farzad ghavam [mailto:ensejam at ns1.tak-host.com] On Behalf
Of
> > > farzad ghavam
> > > Sent: Friday, December 01, 2006 9:32 PM
> > > To: Ronnie Louie
> > > Subject: RE: Please help me
> > > hi Ronnie,
> > > Sorry fro my late,I reinstall Mapguideopensource 1.0.2 and
> > reinstall
> > > FDO.R071, then create an ODBC then create a connection to this
ODBC
> > > (test connection is OK).In database I have a table
> > > (IDCity,NameCity,LatCity,LonCity).Now when I want create a layer
> > from
> > > this connection, cann't read the Geometry fields, I attached two
> > > pictures previous and Now status.
> > > please help me.
> > > thanks,
> > > farzad
> > > > Hi Farzad,
> > > > Have you tried reinstalling MapGuide? Or maybe just re-
> installing
> > > FDO?
> > > > Is this only happening with ODBC, what about SDF?
> > > > There are a bunch of fixes and enhancements in version 1.0.2.
> > Have
> > > you
> > > > tried working with this latest version?
> > > > I will also suggest next time posting this to the mailing list
> > > > users at mapguide.osgeo.org where we can draw on the collective
> > > knowledge
> > > > of others. There may be others who have seen this problem,
and
> > > others
> > > > who may have the solution to this problem.
> > > > Ronnie
Behalf
> Of
> > > > farzad ghavam
> > > > Sent: Sunday, November 05, 2006 5:28 AM
> > > > To: Ronnie Louie
> > > > Subject: Please help me
> > > > hi Ronnie,
> > > > How are you? I have a problem with data in a databse to view
> them.
> > > > I have a table in a xxx.mdb file that contain these filesd:
> > > > ID -> Long (P)
> > > > Name -> Text
> > > > Latitude -> Double
> > > > Longitude -> Double
> > > > before when this I create an ODBC and then create a
connection
> in
> > > > Mapguide studio and then create a layer from this resource, I
> had
> > a
> > > > geometry filed(it was set itself) and I can change any style
of
> > them.
> > > > but now I cann't do it.I don't know why?
> > > > I use MapGuide Server (Version 1.0.1.17812) and MapGuide Site
> > > > Administrator (Version 1.0.1.17812).
> > > > please help me.
> > > > thanks,
> > > > farzad.
> > > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: image/pjpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061214/1b037fa2/attachment.bin
More information about the Mapguide-users
