tuning mapguide performance [No Viruses detected]
Kencana
bluesky_dyx at hotmail.com
Thu Dec 14 21:18:13 EST 2006
Hi Traian,
When I run this stress test, the cpu usage of the web server can reach until
100%.
how ever it is not always at 100 %. while the pf usage of the web server can
reach up to 3GB++.
anyway, our map server is located on different server from the web server.
The following is the event log message from the map server:
1. The description for Event ID ( 0 ) in Source ( MapGuide Server ) cannot
be found. The local computer may not have the necessary registry information
or message DLL files to display messages from a remote computer. You may be
able to use the /AUXSOURCE= flag to retrieve this description; see Help and
Support for details. The following information is part of the event: Cannot
establish connection.
Exception occurred in method MgServerConnection.Open at line 95 in file
.\Services\ServerConnection.cpp.
2. The description for Event ID ( 0 ) in Source ( MapGuide Server ) cannot
Support for details. The following information is part of the event: Server
starting... .
by the way, when i test on the map tiled for 1000 users in 10 minutes, it
seems like the web server is running out
of memory, so it gave me "virtual memory low" error message. after getting
this error message the map server
will die and i have to restart it again for me to access the map.take note
that, the web server ram is 1gb.
any idea of this?
Regards,
Kencana
Traian Stanev wrote:
> May be you ran out of memory because of the 1024 threads that you
> configured the server to spawn?
> Anyway, you are still not telling us why exactly the server process
> dies. Can you check on memory usage, the log files, etc?
> Traian
> -----Original Message-----
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Wednesday, December 13, 2006 9:54 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] RE: RE: tuning mapguide performance [No
> Viruses detected]
> Hi Tom,
> Can I know how you change the registry settings, so that i can raise the
> capacity of fastcgi.
> Anyway i have modify the server setting through the mapguide site admin,
> and i increase the max connection,queuesize,thread pool into 1024 of the
> site server part.
> and as for the result after i test for 1200 users the server never die.
> how ever i keep getting the following error messages at the server
> machine:
> 1. PHP Startup: Unable to load dynamic library 'C:\Program
> Files\MapGuideOpenSource\WebServerExtentions\Php\ext\php_MapGuideAPI.dll
> ' - the paging file is too small for this operations to complete.
> 2. PHP Startup: Unable to load dynamic library 'C:\Program
> ' - this application has failed to start because the application
> configuration is incorrect. Reinstalling the application may fix this
> problem.
> 3. PHP Startup: Unable to load dynamic library 'C:\Program
> ' - A dynamic link library (DLL) initialization routine failed.
> Any idea of this?Any suggestion?
> Thank you
> Regards,
> Kencana
> Tom Chadwin wrote:
>> Hi Kencana
>> You can try changing a couple of registry settigns which raise the
>> capacity of FastCGI, assuming your hardware has extra unused
> capability.
>> Have a look at this thread:
>> http://www.nabble.com/Server-Error%2C-unable-to-connect-to-fastcgi-ser
>> ve
>> r.--No-Viruses-detected--tf2631043.html#a7500851
>> Hope this helps
>> Tom
>> Tom Chadwin
>> ICT & Web Development Officer
>> Telephone: 01434 611530
>> Mobile:
>> Fax: 01434 611677
>> Email: tom.chadwin at nnpa.org.uk
>> Web : www.Northumberland-national-park.org.uk
>> <http://www.Northumberland-national-park.org.uk>
>> <http://www.northumberland-national-park.org.uk/>
>> ______________________________________________________________________
>> ______ IMPORTANT NOTICE - Disclaimer - December 13, 2006 - REF
>> Email-200612-00055591.
>> If you have received this e-mail in error or wish to read our e-mail
>> disclaimer statement and monitoring policy, please refer to the
>> statement below or contact the sender.
>> This communication is from Northumberland National Park Authority
>> (NNPA).The Authority's head office and principal place of business is
>> Eastburn, South Park, Hexham, Northumberland, NE46 1BS, United
>> Kingdom.This communication and any attachments contain information
>> which is confidential and may also be privileged. It is for the
>> exclusive use of users at mapguide.osgeo.org. If you are not the intended
>> recipient(s) please note that any form of disclosure, distribution,
>> copying or use of this communication or the information in it or in
>> any attachments is strictly prohibited and may be unlawful. If you
>> have received this communication in error, please return it with the
>> title "received in error" to "it.security at nnpa.org.uk" then delete the
>> email and destroy any copies of it.
>> E-mail communications cannot be guaranteed to be secure or error free,
>> as information could be intercepted, corrupted, amended, lost,
>> destroyed, arrive late or incomplete, or contain viruses. We do not
>> accept liability for any such matters or their consequences. Anyone
>> who communicates with us by e-mail is taken to accept the risks in
> doing so.
>> Any views or opinions presented are solely those of the author and do
>> not necessarily represent those of NNPA.Contractors or potential
>> contractors are reminded that a formal Order or Contract is needed for
>> NNPA to be bound by any offer or acceptance of terms for the supply of
>> goods or services Although this email and any attachments are believed
>> to be free of any virus or other defects which might affect any
>> computer or IT system into which they are received, no responsibility
>> is accepted by the NNPA for any loss or damage arising in any way from
> the receipt or use thereof.
>> Computer systems of this Authority may be monitored and communications
>> carried out on them recorded, to secure the effective operation of the
>> system and for other lawful purposes.
>> Sent: 13 December 2006 08:50
>> Subject: [mapguide-users] RE: tuning mapguide performance [No Viruses
>> detected]
>> Hi Willem,
>> I am using Microsoft Web Application Stress Testing (WAST) to test.
>> currently i haven't try to use the JMeter.maybe I ll try it later..
>> Anyway, once you have test your server, can you tell me how much is
>> the max user access your server can handle?
>> Thank you
>> Regards,
>> Kencana
>> Willem Schwarte wrote:
>>> Are you using JMeter as Traian said, or another program?
>>> I'd like to test my server too...
>>> -----Oorspronkelijk bericht-----
>>> Van: Kencana [mailto:bluesky_dyx at hotmail.com]
>>> Verzonden: woensdag 13 december 2006 8:13
>>> Aan: users at mapguide.osgeo.org
>>> Onderwerp: Re: [mapguide-users] tuning mapguide performance
>>> The web server is running on Windows 2003 server. with 1 gb ram and
>>> 2.8Ghz Dual Core Plat form.
>>> Currently we are testing it by using 800 simulation users.but it
>>> seems
>>> that mapguide server can't support it.
>>> can I know what you mean by page optimizations?
>>> both map and web server are installed in different machine.
>>> so can we tune the mapguide performance to improve it?
>>> if can, can i know how it can be done?
>>> Regards,
>>> Kencana
>>> Jose Manuel C G wrote:
>>>> This factor depend: os, web server, page optimizations. Be more
>>> specific
>>>> to solve this.
>>>> Kencana wrote:
>>>>> Hi all,
>>>>> is there a way to improve the mapguide performance?
>>>>> As i have try to access to the map and perform some search address
>>>>> function by simulating 1000 users are accessing in 10 minutes, the
>>>>> mapguide server die. So I need
>>> to
>>>>> keep restarting
>>>>> so that users can access the map.
>>>>> I was wondering how to improve the performance as there might me
>>>>> more than 100000 users will access the map.
>>>>> Thank you
>>>>> Regards,
>>>>> Kencana
>>> View this message in context:
>>> http://www.nabble.com/tuning-mapguide-performance-tf2812176.html#a784
>>> 8
>>> 14
>>> 5
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
>> http://www.nabble.com/tuning-mapguide-performance-tf2812176.html#a7849
>> 13
>> 6
> http://www.nabble.com/tuning-mapguide-performance-tf2812176.html#a786603
> 9
View this message in context: http://www.nabble.com/tuning-mapguide-performance-tf2812176.html#a7885225
More information about the Mapguide-users
