[mapguide-users] RE: Please help me (ODBC configuraton problem)
farzad ghavam ghavam at ehealth.ir
Sat Dec 16 04:41:25 EST 2006
Hi Tom,
Thanks for your intrest, I overwrite your sended XML file, but It's
not correct, in "Connection Properties" , I have 5 items, the last
item is "GenarateDefaultGeometryProperty" that I can write any thing,
But I don't know what must be write, I attached a picture and point it.
thanks,
farzad
> Hi Farzad,
> The wrong editor is coming up in your Studio.  The editors for the
> feature sources are configured in the providereditormap.xml file in
the
> Studio executable directory.  There should be an entry for ODBC in
> there:
>     <Entry>
>         <ProviderName>OSGeo.ODBC</ProviderName>
<Editor>Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.OdbcEditor</Ed
i
> tor>
>     </Entry>
> I have attached a copy of the ProviderEditorMap.xml file that is
> installed with Studio.  If you overwrite your existing file with this
> version, you will get back to the default settings.
> Hope that this solves the problem
> Tom
> -----Original Message-----
> From: farzad ghavam [mailto:ensejam at ns1.tak-host.com] On Behalf Of
> farzad ghavam
> Sent: Thursday, December 14, 2006 12:23 AM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] RE: Please help me
> Hi Rouni,
> thank you for guide,
> but when I want create a data connection ,In this page I haven't any
> item named "Define Data Setup", so I cann't select the tables,I
attached
> to you a picture of this Page .
> thanks,
> farzad
> > Hi Farzad,
> > Here's the steps I used to successfully create a layer from either
> the
> > CityLimit table or the SubCityLimit table from your Access
> database.  I
> > am also attaching some screenshots for your reference.
> > 1.  Create an ODBC datasource for the database via
> > Start->Settings->Control Panel->Administrative Tools->Data Sources
> > (ODBC).  Click the System DSN tab.  2.  Click the Add button.
Select
> > Microsoft Access driver.  Click Finish.
> > 3.  Enter a name for the datasource, and click Select button to
pick
> the
> > .mdb file.  Click OK.
> > 4.  Start MapGuide Studio and connect to a site.
> > 5.  Click File->New->Data Connection.
> > 6.  Select OSGeo FDO Provider for ODBC.
> > 7.  Choose the Data Source Name radio button and click on the "..."
> > button to select the datasource you created in step 3.
> > 8.  Under the Refine Data Setup, Click the Show Tables button.
> Click on
> > the Geometry checkbox CityLimit and SubCityLimity.  The X and Y
> Columns
> > should be automatically populate with CityLat and CityLon.
> > 9.  Save the datasource.  You should now be able to use this
feature
> > source to define a new layer.  Select the table (Feature Class) to
> use
> > (either Default:CityLimit or Default:SubCityLimit), and you should
> see
> > the cities geometries displayed in the layer preview.
> > Ronnie
> > From: farzad ghavam [mailto:ghavam at ehealth.ir]
> > Sent: Monday, December 11, 2006 10:38 PM
> >  Hi Ronnie,
> >    please find attachments.
> >  Thanks
> >  Farzad.
> > > Farzad,
> > > My email client (Microsoft Outlook) blocks attachments with .mdb
> > > extension for security reasons.  Can you rename your file to a
> > different
> > > extension and resend it please?
> > > Thanks
> > > Ronnie
> > > Sent: Friday, December 08, 2006 11:28 PM
> > > Subject: Re: [mapguide-users] RE: Please help me
> > > Hi Ronnie,
> > > Thanks for reply, My .mdb file has 3 tables and I try by 1 table
> but
> > > not worked,Now I send .mdb file and two pictures of my project,
I
> > > don't know What do I do?
> > > Farzad.
> > > > Hi Farzad,
> > > > Do you mind sending me your Access database file?  In the
> > meantime,
> > > Is
> > > > there more than one table in the database?  If yes, maybe you
> > could
> > > try
> > > > modifying your .mdb a bit such that it only contains one table
> and
> > > let
> > > > me know what happens.
> > > > Ronnie
> Of
> > > > farzad ghavam
> > > > Sent: Friday, December 01, 2006 9:32 PM
> > > > To: Ronnie Louie
> > > > Subject: RE: Please help me
> > > > hi Ronnie,
> > > >  Sorry fro my late,I reinstall Mapguideopensource 1.0.2 and
> > > reinstall
> > > > FDO.R071, then create an ODBC then create a connection to this
> ODBC
> > > > (test connection is OK).In database I have a table
> > > > (IDCity,NameCity,LatCity,LonCity).Now when I want create a
layer
> > > from
> > > > this connection, cann't read the Geometry fields, I attached
two
> > > > pictures previous and Now status.
> > > > please help me.
> > > > thanks,
> > > > farzad
> > > > > Hi Farzad,
> > > > > Have you tried reinstalling MapGuide?  Or maybe just re-
> > installing
> > > > FDO?
> > > > > Is this only happening with ODBC, what about SDF?
> > > > > There are a bunch of fixes and enhancements in version
1.0.2.
> > > Have
> > > > you
> > > > > tried working with this latest version?
> > > > > I will also suggest next time posting this to the mailing
list
> > > > > users at mapguide.osgeo.org where we can draw on the collective
> > > > knowledge
> > > > > of others.  There may be others who have seen this problem,
> and
> > > > others
> > > > > who may have the solution to this problem.
> > > > > Ronnie
> Behalf
> > Of
> > > > > farzad ghavam
> > > > > Sent: Sunday, November 05, 2006 5:28 AM
> > > > > To: Ronnie Louie
> > > > > Subject: Please help me
> > > > > hi Ronnie,
> > > > >  How are you? I have a problem with data in a databse to view
> > them.
> > > > >  I have a table in a xxx.mdb file that contain these filesd:
> > > > >   ID        -> Long (P)
> > > > >   Name      -> Text
> > > > >   Latitude  -> Double
> > > > >   Longitude -> Double
> > > > >  before when this I create an ODBC and then create a
> connection
> > in
> > > > > Mapguide studio and then create a layer from this resource, I
> > had
> > > a
> > > > > geometry filed(it was set itself) and I can change any style
> of
> > > them.
> > > > > but now I cann't do it.I don't know why?
> > > > > I use MapGuide Server (Version 1.0.1.17812) and MapGuide
Site
> > > > > Administrator (Version 1.0.1.17812).
> > > > > please help me.
> > > > > thanks,
> > > > > farzad.
> > > > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > > For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: image/pjpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061216/6337ba70/attachment.bin
More information about the Mapguide-users mailing list
