[mapguide-users] MgException - MgOutofMememory - Out of memory.
Bruce Dechant bruce.dechant at autodesk.com
Sun Dec 17 12:36:36 EST 2006
Kori,
Thanks for the update. I'll take a look at the source code and see if there is something that could cause what you are seeing from the information you have given.
Thanks,
Bruce
	-----Original Message-----
	Sent: Sat 12/16/2006 12:20 AM
	Cc:
	Subject: RE: [mapguide-users] MgException - MgOutofMememory - Out of memory.
	I watched it for over 3 hours and observed the point of the error.
	Most exciting Friday night ever.
	I don't think it is a memory error - the memory usage stayed relatively
	flat.  The increase over time ended up being minimal.
	I think there is a loss of connectivity just prior that results in the error
	being thrown.  Perhaps the site connection expires - and the way the
	function is written it does the next GetTile but not without rights.
	Hard to tell which is cause and which is effect.
	I just checked the Access log and that confirms it.
	Before error:
	<2006-12-15T22:21:39>                   Administrator
	GetTile.1:4(MgMap,Map,tileCol,tileRow) Success
	<2006-12-15T22:21:41>                   Administrator
	<2006-12-15T22:21:42>                   Administrator
	Error thrown:
	<2006-12-15T22:21:43>                   Administrator
	GetTile.1:4(MgMap,Map,tileCol,tileRow) Failure
	If I try to continue past the error by restarting my application but not
	restarting the MapGuide Server service (notice the Admin account is not
	present and there is no CreateSession etc):
	<2006-12-15T22:23:45>
	If I restart the MapGuide Service:
	<2006-12-15T22:49:24>                   Administrator   CreateSession.1:0()
	Success
	GetResourceContent.1:2(MgResourceIdentifier,) Success
	<2006-12-15T22:49:29>                   Administrator
	It does the initial config correctly.
	In my ServerConfig.ini I have the following settings:
	SessionTimerInterval = 400
	SessionTimeout = 86400
	I do an HTTP call within the 400 second interval to keep the session fresh.
	I will continue to review my code to see if I am missing something.
	Is the session expiring or failing in some manner possibly?
	Cheers and thanks,
	Kori
	Sent: December 15, 2006 7:32 PM
	I am using MapGuide Enterprise Service Pack 1 for this test.  The more
	recent Open build may fare better.  I am still in the process of getting a
	machine up.
	Increasing the paging file didn't work.  It still threw the Out of memory
	error.  I missed the actual occurrence of the error - so I am not sure if
	the memory usage peaked unusually high - I don't think it did.
	It only got to 336000 k.
	If I tried to re-run my process I got the same error.
	If I restarted MapGuide Service, it ran fine.
	So I am not sure if it is truly a memory error or a loss of connectivity
	before.
	I will keep running and documenting over the weekend.
	Cheers,
	The sequence of errors according to the log file:
	<2006-12-15T19:09:31>                   Administrator
	 Error: Failed to stylize layer: 100K_Urban_California
	        An unclassified exception occurred.
	 StackTrace:
	  - MgStylizationUtil.StylizeLayers line 993 file
	c:\build_tux_area\mgdev\server\src\services\mapping\StylizationUtil.cpp
	 Error: Failed to stylize layer: 2M_ocean_mask_California
	        Out of memory.
	        bad allocation
	 StackTrace:
	Out of memory.
	bad allocation
	<2006-12-15T19:09:32>                   Administrator
	 Error: Out of memory.
	        bad allocation
	 StackTrace:
	  - MgTileServiceHandler.ProcessOperation line 83 file
	c:\build_tux_area\mgdev\server\src\services\tile\TileServiceHandler.cpp
	  - MgOpGetTile.Execute line 97 file
	c:\build_tux_area\mgdev\server\src\services\tile\OpGetTile.cpp
	  - MgServerTileService.GetTile line 85 file
	c:\build_tux_area\mgdev\server\src\services\tile\ServerTileService.cpp
	  - MgServerTileService.SetTile line 119 file
	  - MgByteSink::ToFile line 245 file
	c:\build_tux_area\mgdev\common\service\data\ByteSink.cpp        Out of
	memory.
	bad allocation
	From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
	Sent: December 15, 2006 6:52 PM
	Kori,
	Can you clarify which version of MapGuide you are using? This will help
	identify whether some of the memory leak issues have been fixed or have not
	been fixed yet in the build you are using.
	Thanks,
	Bruce
	From:   Kori Maleski [mailto:Kori.Maleski at websoftdev.com]
	Sent:   Fri 12/15/2006 6:24 PM
	Cc:
	memory.
	The memory usage does increase slightly overtime.
	Over a 45 minute time period it went from an average of 291000 to 301000 k -
	that's about 2000 tiles.  It is still increasing slowly.
	I will be running it over the weekend and monitor the memory usage as best I
	can.
	I can specify my starting tile column when I restart, so I do not have to
	redo any processing when it throws the error.
	Thanks Walt,
	Cheers,
	Kori
	  _____
	From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
	Sent: December 15, 2006 4:19 PM
	Does the server memory usage slowly increase with time?  What is it after
	generating 1000 / 2000 / 3000 tiles?  If you're generating tiles
	sequentially the memory should remain relatively flat.  I wouldn't be
	surprised if there are still some leaks we have to track down.
	Walt
	  _____
	Sent: Saturday, December 16, 2006 1:12 AM
	Upped the page file size.  Hopefully that is the issue.
	Cheers,
	  _____
	Sent: December 15, 2006 11:05 AM
	Here is the stack trace on that:
	<2006-12-15T05:10:54>                          Administrator
	 StackTrace:
	        Out of memory.
	        bad allocation
	 StackTrace:
	Out of memory.
	bad allocation
	        bad allocation
	 StackTrace:
	c:\build_tux_area\mgdev\common\service\data\ByteSink.cpp      Out of memory.
	bad allocation
	  _____
	 <http://www.websoftdev.com/>
	Kori Maleski
	Senior Application Developer
	WEBSOFT DEVELOPERS, INC.
	P: (530) 759-8754 ext 114
	F: (530) 759-0923
	kori.maleski at websoftdev.com
	  _____
	  _____
	Sent: December 15, 2006 10:29 AM
	Subject: [mapguide-users] MgException - MgOutofMememory - Out of memory.
	Hi all,
	I am in the process of error trapping a tiling process in an application
	using the MgTileService Class.
	I am sequentially executing the GetTile function over a long duration.
	I am encountering a "Out of memory." Error after 3.5 hours of processing
	time on trial runs.
	During each trial:
	-          The error occurred after the same length of time
	-          5000 to 7000 tiles have been retrieved (the difference I am
	assuming being a result of the variance in the amount of features required
	to build the tile)
	-          the last file being written is 0 kb ( I am assuming it was opened
	for writing as the error occurred)
	-          the MapGuide Server service was running but non-responsive and
	had to be restarted
	Is this error a result of the following:
	-          file I/O write issue?
	-          too many tile requests in the queue or being made too often?
	-          Something specific to the RAM on the machine I am running the
	process on?
	Is there a way to trap this and recover?
	Anybody have any recommendations?
	Cheers,
	  _____
	Kori Maleski
	F: (530) 759-0923
	  _____
	To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
	For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061217/a8d5a2d0/attachment.bin
More information about the Mapguide-users mailing list
