[mapguide-users] RE: Please help me (ODBC configuraton problem)
farzad ghavam
ghavam at ehealth.ir
Tue Dec 19 06:43:03 EST 2006
Hi Tom and Rouni,
Thank you for your comments, My Autodek MapGuide Studio software was
Corrupt. I download last version and reinstall it, Now I view
the "Refine Data Setup" Item and I can set the fileds.
Thanks,
farzad
> Hi Farzad,
> The wrong editor is still coming up in your Studio. I'm not sure
why.
> But you could try reinstalling it, or installing on a different
computer
> to see if that solves things.
> Tom
> -----Original Message-----
> From: farzad ghavam [mailto:ensejam at ns1.tak-host.com] On Behalf Of
> farzad ghavam
> Sent: Saturday, December 16, 2006 2:41 AM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] RE: Please help me (ODBC configuraton
> problem)
> Hi Tom,
> Thanks for your intrest, I overwrite your sended XML file, but It's
not
> correct, in "Connection Properties" , I have 5 items, the last item
is
> "GenarateDefaultGeometryProperty" that I can write any thing, But I
> don't know what must be write, I attached a picture and point it.
> thanks,
> farzad
> > Hi Farzad,
> > The wrong editor is coming up in your Studio. The editors for the
> > feature sources are configured in the providereditormap.xml file in
> the
> > Studio executable directory. There should be an entry for ODBC in
> > there:
> > <Entry>
> > <ProviderName>OSGeo.ODBC</ProviderName>
<Editor>Autodesk.MapGuide.Studio.UI.FeatureSourceEditors.OdbcEditor</Ed
> i
> > tor>
> > </Entry>
> > I have attached a copy of the ProviderEditorMap.xml file that is
> > installed with Studio. If you overwrite your existing file with
this
> > version, you will get back to the default settings.
> > Hope that this solves the problem
> > Tom
> > farzad ghavam
> > Sent: Thursday, December 14, 2006 12:23 AM
> > Hi Rouni,
> > thank you for guide,
> > but when I want create a data connection ,In this page I haven't
any
> > item named "Define Data Setup", so I cann't select the tables,I
> attached
> > to you a picture of this Page .
> > thanks,
> > farzad
> > > Hi Farzad,
> > > Here's the steps I used to successfully create a layer from
either
> > the
> > > CityLimit table or the SubCityLimit table from your Access
> > database. I
> > > am also attaching some screenshots for your reference.
> > > 1. Create an ODBC datasource for the database via
> > > Start->Settings->Control Panel->Administrative Tools->Data
Sources
> > > (ODBC). Click the System DSN tab. 2. Click the Add button.
> Select
> > > Microsoft Access driver. Click Finish.
> > > 3. Enter a name for the datasource, and click Select button to
> pick
> > the
> > > .mdb file. Click OK.
> > > 4. Start MapGuide Studio and connect to a site.
> > > 5. Click File->New->Data Connection.
> > > 6. Select OSGeo FDO Provider for ODBC.
> > > 7. Choose the Data Source Name radio button and click on
the "..."
> > > button to select the datasource you created in step 3.
> > > 8. Under the Refine Data Setup, Click the Show Tables button.
> > Click on
> > > the Geometry checkbox CityLimit and SubCityLimity. The X and Y
> > Columns
> > > should be automatically populate with CityLat and CityLon.
> > > 9. Save the datasource. You should now be able to use this
> feature
> > > source to define a new layer. Select the table (Feature Class)
to
> > use
> > > (either Default:CityLimit or Default:SubCityLimit), and you
should
> > see
> > > the cities geometries displayed in the layer preview.
> > > Ronnie
> > > From: farzad ghavam [mailto:ghavam at ehealth.ir]
> > > Sent: Monday, December 11, 2006 10:38 PM
> > > Hi Ronnie,
> > > please find attachments.
> > > Thanks
> > > Farzad.
> > > > Farzad,
> > > > My email client (Microsoft Outlook) blocks attachments
with .mdb
> > > > extension for security reasons. Can you rename your file to a
> > > different
> > > > extension and resend it please?
> > > > Thanks
> > > > Ronnie
> > > > Sent: Friday, December 08, 2006 11:28 PM
> > > > Subject: Re: [mapguide-users] RE: Please help me
> > > > Hi Ronnie,
> > > > Thanks for reply, My .mdb file has 3 tables and I try by 1
table
> > but
> > > > not worked,Now I send .mdb file and two pictures of my project,
> I
> > > > don't know What do I do?
> > > > Farzad.
> > > > > Hi Farzad,
> > > > > Do you mind sending me your Access database file? In the
> > > meantime,
> > > > Is
> > > > > there more than one table in the database? If yes, maybe you
> > > could
> > > > try
> > > > > modifying your .mdb a bit such that it only contains one
table
> > and
> > > > let
> > > > > me know what happens.
> > > > > Ronnie
Behalf
> > Of
> > > > > farzad ghavam
> > > > > Sent: Friday, December 01, 2006 9:32 PM
> > > > > To: Ronnie Louie
> > > > > Subject: RE: Please help me
> > > > > hi Ronnie,
> > > > > Sorry fro my late,I reinstall Mapguideopensource 1.0.2 and
> > > > reinstall
> > > > > FDO.R071, then create an ODBC then create a connection to
this
> > ODBC
> > > > > (test connection is OK).In database I have a table
> > > > > (IDCity,NameCity,LatCity,LonCity).Now when I want create a
> layer
> > > > from
> > > > > this connection, cann't read the Geometry fields, I attached
> two
> > > > > pictures previous and Now status.
> > > > > please help me.
> > > > > thanks,
> > > > > farzad
> > > > > > Hi Farzad,
> > > > > > Have you tried reinstalling MapGuide? Or maybe just re-
> > > installing
> > > > > FDO?
> > > > > > Is this only happening with ODBC, what about SDF?
> > > > > > There are a bunch of fixes and enhancements in version
> 1.0.2.
> > > > Have
> > > > > you
> > > > > > tried working with this latest version?
> > > > > > I will also suggest next time posting this to the mailing
> list
> > > > > > users at mapguide.osgeo.org where we can draw on the
collective
> > > > > knowledge
> > > > > > of others. There may be others who have seen this problem,
> > and
> > > > > others
> > > > > > who may have the solution to this problem.
> > > > > > Ronnie
> > Behalf
> > > Of
> > > > > > farzad ghavam
> > > > > > Sent: Sunday, November 05, 2006 5:28 AM
> > > > > > To: Ronnie Louie
> > > > > > Subject: Please help me
> > > > > > hi Ronnie,
> > > > > > How are you? I have a problem with data in a databse to
view
> > > them.
> > > > > > I have a table in a xxx.mdb file that contain these
filesd:
> > > > > > ID -> Long (P)
> > > > > > Name -> Text
> > > > > > Latitude -> Double
> > > > > > Longitude -> Double
> > > > > > before when this I create an ODBC and then create a
> > connection
> > > in
> > > > > > Mapguide studio and then create a layer from this
resource, I
> > > had
> > > > a
> > > > > > geometry filed(it was set itself) and I can change any
style
> > of
> > > > them.
> > > > > > but now I cann't do it.I don't know why?
> > > > > > I use MapGuide Server (Version 1.0.1.17812) and MapGuide
> Site
> > > > > > Administrator (Version 1.0.1.17812).
> > > > > > please help me.
> > > > > > thanks,
> > > > > > farzad.
> > > > > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > > > For additional commands, e-mail: users-
help at mapguide.osgeo.org
> > > > For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
