[mapguide-users] Trouble Adding Existing Layers Programmatically
Jason Birch
Jason.Birch at nanaimo.ca
Wed Dec 20 10:18:19 EST 2006
Code might help with diagnosis.
You're saving the map back to the session repository after adding the layer, right?
Jason
Sent: Wed 2006-12-20 5:48 AM
Subject: [mapguide-users] Trouble Adding Existing Layers Programmatically
I have some layers that exist in my repository, but aren't added to the published map with Studio. Instead, I want end users to be able to add and remove these layers from the repository at runtime. I'm using the MgLayerCollection.Add method to display layers, but they don't show up in the map. According to the developers guide, firing this method should automatically add a layer to the map (p. 48). The layers I'm trying to add do get added to the collection, but don't display even after performing a MgLayer.Visible=True and MgLayer.ForceRefresh. I am also calling the Viewer API to refresh: parent.mapFrame.Refresh().
Anyone have any suggestions or sample code?
Regards,
Shane
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061220/0b9060c4/attachment.bin
More information about the Mapguide-users
