[mapguide-users] Trouble Adding Existing Layers Programmatically
Kori Maleski
Kori.Maleski at websoftdev.com
Wed Dec 20 14:04:04 EST 2006
You're not saving the map back to the Session.
Try something like this after you have added the layercollection:
'Create Identifier for the Session Map
Dim l_oSessionResourceIdentifier As New
MgResourceIdentifier("Session:" & Session & "//" & MapName & ".Map")
'Save the Session Map
l_oMap.Save(l_oResourceSrvc, l_oSessionResourceIdentifier)
Kori
Kori Maleski
Senior Application Developer
WEBSOFT DEVELOPERS, INC.
P: (530) 759-8754 ext 114
F: (530) 759-0923
kori.maleski at websoftdev.com
_____
From: Buscher, Shane [mailto:Shane.Buscher at nngco.com]
Sent: December 20, 2006 8:37 AM
Subject: RE: [mapguide-users] Trouble Adding Existing Layers
Programmatically
I am overlooking saving the map back to the session repository, which sounds
like my problem. I'll look into this. Here's the code if you have any
other suggestions:
Dim webConfig As String = Request.ServerVariables("APPL_PHYSICAL_PATH") &
"webconfig.ini"
MapGuideApi.MgInitializeWebTier(webConfig)
GetRequestParameters() 'gets mapName and sessionID
Dim userInfo As New MgUserInformation(sessionId)
Dim siteConn As New MgSiteConnection
siteConn.Open(userInfo)
Dim resourceService As MgResourceService =
siteConn.CreateService(MgServiceType.ResourceService)
map.Open(resourceService, mapName)
Dim resId As New
MgResourceIdentifier("Library://VST_Prototype/Layers/SouthOmahaValves.LayerD
efinition")
Dim layerCollection As MgLayerCollection = map.GetLayers()
Dim lyr As New MgLayer(resId, resourceService)
layerCollection.Add(lyr)
lyr.SetVisible(True)
lyr.SetDisplayInLegend(True)
lyr.ForceRefresh()
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, December 20, 2006 9:18 AM
Programmatically
Code might help with diagnosis.
You're saving the map back to the session repository after adding the layer,
right?
Jason
_____
Sent: Wed 2006-12-20 5:48 AM
Subject: [mapguide-users] Trouble Adding Existing Layers Programmatically
I have some layers that exist in my repository, but aren't added to the
published map with Studio. Instead, I want end users to be able to add and
remove these layers from the repository at runtime. I'm using the
MgLayerCollection.Add method to display layers, but they don't show up in
the map. According to the developers guide, firing this method should
automatically add a layer to the map (p. 48). The layers I'm trying to add
do get added to the collection, but don't display even after performing a
MgLayer.Visible=True and MgLayer.ForceRefresh. I am also calling the Viewer
API to refresh: parent.mapFrame.Refresh().
Anyone have any suggestions or sample code?
Regards,
Shane
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20061220/591b2f77/attachment.html
More information about the Mapguide-users
