[mapguide-users] Re: PLease Help He
Ivan Miličević
ivan at ineo.hr
Tue Jul 4 03:50:55 EDT 2006
https://mapguide.osgeo.org/docs/BuildConfigureMgOpenSourceOnWindows.pdf
Did you follow instructions in this file?
What is your system configuration? OS?
_____
From: sukalyan chakraborty [mailto:chakraborty.sarkar at gmail.com]
Sent: 4. srpanj 2006 7:53
Subject: Re: [mapguide-users] Re: PLease Help He
Yes the problem solved now next problem
Resource was not found:
Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout
Library://Samples/Sheboygan/Layouts/SheboyganAsp.WebLayout Exception
occurred in method MgResourceDefinitionManager.GetDocument at line 483 in
file
c:\build_tux_area\mgdev\server\src\services\resource\ResourceDefinitionManag
er.cpp
now if i go to load the resource using
http://localhost/mapguide/mapadmin/login.php
Using Administrator & admin as uname & pass
It gives the another error:
Fatal error: Call to undefined function MgInitializeWebTier() in C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapadmin\login.php on line
68
Please Help Me Again.
On 7/4/06, Andy Morsell <amorsell at spatialgis.com> wrote:
Try adding C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin to your
Windows path, reboot, and try again.
Andy
_____
Sent: Monday, July 03, 2006 10:12 PM
Subject: SPAM-LOW: [mapguide-users] Re: PLease Help He
Hi
I'm Tll now facing same problems.
Is there any more solution ???
I've checked the framework version & keeping the bin folder inside the
samples
& also keeping the all dlls open from the bin folder.
Inspite of that i'm getting same error.
On 6/30/06, sukalyan chakraborty <chakraborty.sarkar at gmail.com
<mailto:chakraborty.sarkar at gmail.com> > wrote:
please help me...
When I'm Running pages from MGStudio then it is running fine but
If I running like
http://localhost/mapguide/dotnetviewersample/ajaxtiledviewersample.aspx
or
http://localhost/mapguide/dotnetviewersample/dwfviewersample.aspx
then getting the error
I'm using Framework v2.0.50727
Server Error in '/mapguide' Application.
_____
Compilation Error
Description: An error occurred during the compilation of a resource required
to service this request. Please review the following specific error details
and modify your source code appropriately.
Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could not
be found (are you missing a using directive or an assembly reference?)
Source Error:
Line 17: <%@ Import Namespace="System.Collections" %>
Line 18: <%@ Import Namespace="System.IO" %>
Line 19: <%@ Import Namespace="OSGeo.MapGuide" %>
Line 20: <script language="c#" runat="server">
Line 21:
Source File: c:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\utilityf
unctions.aspx Line: 19
Show Detailed Compiler Output:
C:\WINDOWS\system32> "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\csc.exe"
/t:library /utf8output
/R:"C:\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11
d50a3a\System.EnterpriseServices.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Services\2.0.0.0__b03f5f7f11d50a
3a\System.Web.Services.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System.Configuration\2.0.0.0__b03f5f7f11d50
a3a\System.Configuration.dll"
/R:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorlib.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System\2.0.0.0__b77a5c561934e089\System.dll
/R:"C:\WINDOWS\assembly\GAC_MSIL\System.Xml\2.0.0.0__b77a5c561934e089\System
.Xml.dll"
/R:"C:\WINDOWS\assembly\GAC_32\System.Data\2.0.0.0__b77a5c561934e089\System.
Data.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System.Web.Mobile\2.0.0.0__b03f5f7f11d50a3a
\System.Web.Mobile.dll"
/R:"C:\WINDOWS\assembly\GAC_MSIL\System.Drawing\2.0.0.0__b03f5f7f11d50a3a\Sy
stem.Drawing.dll"
/R:"C:\WINDOWS\assembly\GAC_32\System.Web\2.0.0.0__b03f5f7f11d50a3a\System.W
eb.dll" /out:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary
ASP.NET <http://asp.net/>
Files\mapguide\6330db03\7cea0d17\App_Web_ajaxtiledviewersample.aspx.305c7238
.rr15dqlk.dll" /debug- /optimize+
/win32res:"C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary
ASP.NET <http://asp.net/> Files\mapguide\6330db03\7cea0d17\3tjlg3zd.res"
/w:4 /nowarn:1659;1699
.rr15dqlk.0.cs" "C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary
.rr15dqlk.1.cs"
Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42
for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727
Copyright (C) Microsoft Corporation 2001-2005. All rights reserved.
c:\Program
unctions.aspx(19,11): error CS0246: The type or namespace name 'OSGeo' could
not be found (are you missing a using directive or an assembly reference?)
c:\Program
unctions.aspx(39,24): error CS0246: The type or namespace name 'MgMap' could
c:\Program
unctions.aspx(39,1): error CS0246: The type or namespace name 'MgLayer'
could not be found (are you missing a using directive or an assembly
reference?)
c:\Program
unctions.aspx(55,26): error CS0246: The type or namespace name
'MgByteReader' could not be found (are you missing a using directive or an
Show Complete Compilation Source:
Line 1: <%--
Line 2: Copyright (C) 2004-2006 Autodesk, Inc.
Line 3: This library is free software; you can redistribute it and/or
Line 4: modify it under the terms of version 2.1 of the GNU Lesser
Line 5: General Public License as published by the Free Software
Foundation.
Line 6:
Line 7: This library is distributed in the hope that it will be useful,
Line 8: but WITHOUT ANY WARRANTY; without even the implied warranty of
Line 9: MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Line 10: Lesser General Public License for more details.
Line 11:
Line 12: You should have received a copy of the GNU Lesser General Public
Line 13: License along with this library; if not, write to the Free
Software
Line 14: Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA
02110-1301 USA
Line 15: --%>
Line 16:
Line 21:
Line 22: NameValueCollection GetParameters()
Line 23: {
Line 24: return Request.HttpMethod == "GET" ? Request.QueryString :
Request.Form;
Line 25: }
Line 26:
Line 27: void InitializeWebTier()
Line 28: {
Line 29: // Initialize web tier with the site configuration file. The
config
Line 30: // file should be in the same folder as this script.
Line 31: //
Line 32: string realPath =
Request.ServerVariables["APPL_PHYSICAL_PATH"];
Line 33: String configPath = realPath + "webconfig.ini";
Line 34: MapGuideApi.MgInitializeWebTier(configPath);
Line 35: }
Line 36:
Line 37: // Searches the map for a layer with the specified name.
Line 38:
Line 39: MgLayer GetLayerByName(MgMap map, String layerName)
Line 40: {
Line 41: MgLayer layer = null;
Line 42: for (int i = 0; i < map.GetLayers().GetCount(); i++)
Line 43: {
Line 44: MgLayer nextLayer = map.GetLayers().GetItem(i);
Line 45: if (nextLayer.GetName() == layerName)
Line 46: {
Line 47: layer = nextLayer;
Line 48: break;
Line 49: }
Line 50: }
Line 51: return layer;
Line 52: }
Line 53:
Line 54: // Read the content from an MgByteReader and send it back as the
response.
Line 55: void OutputReaderContent(MgByteReader byteReader, HttpResponse
response)
Line 56: {
Line 57: MemoryStream memBuf = new MemoryStream();
Line 58:
Line 59: byte[] byteBuffer = new byte[1024];
Line 60: int numBytes = byteReader.Read(byteBuffer, 1024);
Line 61: while(numBytes > 0)
Line 62: {
Line 63: memBuf.Write(byteBuffer, 0, numBytes);
Line 64: numBytes = byteReader.Read(byteBuffer, 1024);
Line 65: }
Line 66:
Line 67: response.ContentType = byteReader.GetMimeType();
Line 68: byte [] content = memBuf.ToArray();
Line 69: response.OutputStream.Write(content , 0, content.Length);
Line 70: }
Line 71:
Line 72: </script>
Line 73:
_____
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET
<http://asp.net/> Version: 2.0.50727.42
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060704/4a889eaa/attachment.html
More information about the Mapguide-users
