[mapguide-users] OSGeo FDO problem...
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Mon Jul 10 10:25:08 EDT 2006
ODBC.....I posted the problem first under PostGIS, but them quickly said
that it wasn't actually PostGIS, and that it was ODBC....sorry if you
missed that!
Traian Stanev wrote:
> I thought the problem was with PostGIS, that's why I used that... So
> the problem actually happens when using an Access DB? Can you
> specifically confirm if that happens when using the ODBC provider or
> the OGR provider?
> Traian
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Monday, July 10, 2006 10:09 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] OSGeo FDO problem...
> Well, all I know is that as soon as I took out the space in the table
> name, it fixed it. I'd say that your test should be (to be consistant
> with what I did) to make an Access DB...Then make a table with a space
> in the name. Then just make 3 fields (a key, a northing and an
> easting). Type in some coords (anything should do) and then try to use
> that. It should crash as soon as you check "geometry".
> Andrew
>> Hi Andrew,
>> I finally had time to look into the OGR/PostGIS problem. MapGuide
>> worked fine with a table that has a space in its name. My table was
>> called "world cities" and contained point data. I also tried adding a
>> simple attribute filter to the layer ("name" > 'L'), and that also
>> worked fine.
>> So, there must be something else going on with your table that's
>> throwing off the SQL. FYI, I created my test table by importing an
>> shp file into pgsql, not sure if that would make a difference.
>> Traian
>> *Sent:* Tuesday, July 04, 2006 9:16 AM
>> Heh.....very understandable!
>> Andrew
>>> Sorry, I have not had a chance to look at this yet. Currently the
>>> problem is that they only have 24 hours in a day...
>>> Traian
>>> -----Original Message-----
>>> From: Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>>> Sent: Fri 6/30/2006 4:03 PM
>>> To: users at mapguide.osgeo.org
>>> Cc:
>>> Subject: Re: [mapguide-users] OSGeo FDO problem...
>>> How's this going? Any progress?
>>> Andrew
>>> > Well, I looked at the code and can't tell offhand why it wouldn't be
>>> > working. I'll have to dust off my postgis and try it with a table name
>>> > with spaces to see what's going on. I'll post again when I've
>>> fixed it.
>>> > Cheers,
>>> > Traian
>>> > Sent: Wed 6/28/2006 10:41 AM
>>> > Cc:
>>> > No filter...
>>> > > Hmm. It could be that the provider is being careless with filter
>>> > > conversion to string. Do you have a filter set on the layer, or are
>>> > > you simply trying to preview the whole layer with no filter?
>>> > > *Sent:* Wednesday, June 28, 2006 9:59 AM
>>> > > I'd love to try that, but where do I have that option? I'm using
>>> > > Studio...I see no place to either use an SQL statement of my own, or
>>> > > to put anything (let alone quotes) around a table name.
>>> > > Andrew
>>> > > Robert Fortin wrote:
>>> > >> Andrew,
>>> > >> Have you tried using single quote around you table name/column?
>>> > >> RF
>>> > >> *Sent:* Wednesday, June 28, 2006 9:24 AM
>>> > >> *Subject:* [mapguide-users] OSGeo FDO problem...
>>> > >> It seems that the OSGeo FDO provider doesn't like spaces in table
>>> > >> names. The error log said that the FDO was causing a "Syntax
>>> error in
>>> > >> FROM clause". Is this something that can be fixed? It should be a
>>> > >> pretty simple fix, really..since I'd guess that all that needs
>>> to be
>>> > >> done is to enclose table names (and field names, for that
>>> matter) in
>>> > >> square brackets (ie, [Table Name], or [Table Name].[Field
>>> Name]). The
>>> > >> work around for me for now is to make another Access database and
>>> > >> link all of the tables from my real database. In this new
>>> database, I
>>> > >> just rename the tables to get rid of the spaces. But I can't really
>>> > >> rely on his workaround, because having to change table names means
>>> > >> changing a lot of other things for other projects (this database is
>>> > >> used in a lot of other ways, not just MapGuide). Is there any
>>> chance
>>> > >> that this FDO can get modified to account for these spaces?
>>> > >> Andrew
>>> > >> *Andrew DeMerchant*
>>> > >> *Computer Technologist*
>>> > >> ph.1-877-4GEMTEC x.163
>>> > >> fax 506-453-9470
>>> > >> /GEMTEC Limited <http://www.gemtec.ca>
>>> > >> /191 Doak Road
>>> > >> Fredericton, NB, Canada
>>> > >> E3C 2E6
>>> > > *Andrew DeMerchant*
>>> > > fax 506-453-9470
>>> > > /191 Doak Road
>>> > > E3C 2E6
>>> > *Andrew DeMerchant*
>>> > fax 506-453-9470
>>> > /191 Doak Road
>>> > E3C 2E6
>>> >To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>> >For additional commands, e-mail: users-help at mapguide.osgeo.org
>>> *Andrew DeMerchant*
>>> fax 506-453-9470
>>> /191 Doak Road
>>> E3C 2E6
>> *Andrew DeMerchant*
>> fax 506-453-9470
>> /191 Doak Road
>> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users
