[mapguide-users] Display Name for Property in Studio
Andy Morsell amorsell at spatialgis.com
Tue Jul 11 13:14:19 EDT 2006
In Studio under the layer properties, in the Name to Display column if you
double-click on the field name, it toggles it on or off. BUT, if you
single-click once to highlight it, then pause and single-click again, you
will be in edit mode where you can type in the "friendly" name you want to
display in the Properties pane in the viewer.  It's sort of like how Windows
Explorer works when renaming files.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
From: Berdel, Brian [mailto:brian.berdel at mcmtrans.com]
Sent: Tuesday, July 11, 2006 9:43 AM
Subject: RE: [mapguide-users] Display Name for Property in Studio
FYI, I meant the properties for the feature data of a layer.
  _____
Sent: Tuesday, July 11, 2006 10:18 AM
Subject: [mapguide-users] Display Name for Property in Studio
Is it not possible to change the Display name for a property in Studio? It
says you are supposed to be able to but I cannot change anything.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060711/86c7c789/attachment.html
More information about the Mapguide-users mailing list
