[mapguide-users] Display Name for Property in Studio
Berdel, Brian brian.berdel at mcmtrans.com
Wed Jul 12 08:14:54 EDT 2006
Thanks Andy, that was it.
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Tuesday, July 11, 2006 1:14 PM
Subject: RE: [mapguide-users] Display Name for Property in Studio
In Studio under the layer properties, in the Name to Display column if
you double-click on the field name, it toggles it on or off. BUT, if you
single-click once to highlight it, then pause and single-click again,
you will be in edit mode where you can type in the "friendly" name you
want to display in the Properties pane in the viewer.  It's sort of like
how Windows Explorer works when renaming files.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
From: Berdel, Brian [mailto:brian.berdel at mcmtrans.com]
Sent: Tuesday, July 11, 2006 9:43 AM
FYI, I meant the properties for the feature data of a layer.
Sent: Tuesday, July 11, 2006 10:18 AM
Subject: [mapguide-users] Display Name for Property in Studio
Is it not possible to change the Display name for a property in Studio?
It says you are supposed to be able to but I cannot change anything.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060712/862fe726/attachment.html
More information about the Mapguide-users mailing list
