[mapguide-users] more linux compile errors than you can shake a stick at
mark j jansenbulk at gmail.com
Fri Jul 14 23:35:38 EDT 2006
Hello Traian and list,
It has solved the libtool errors, but there are errors in the compile
nonetheless. Below is how far I  get until the it is unclear on how I should
modify ChannelBand.h. When I modify these files, it produces a binary that
immediately segfaults.
building OEM with build_oem.sh produces one error:
Source/Modules/java.cxx:3582: error: extra qualification 'JAVA::' on member
'abstractClassTest'
building mapguide
fitdataset.cpp:177: error: extra qualification 'FITRasterBand::' on member
'FITRasterBand'
ChannelBand.h:77: error: explicit instantiation of 'class
std::auto_ptr<MdfModel::ChannelBand>' in namespace 'MdfModel' (which does
not enclose namespace 'std'r)
I will continue with the build if anyone has a suggestion on how to solve
the ChannelBand header namespace error. Removing std:: only produces another
error:
ChannelBand.h:77: error: 'auto_ptr' is not a template
ChannelBand.h:77: error: explicit instantiation of non-template type
'MdfModel::auto_ptr'
Kind Regards,
Mark
On 7/13/06, Traian Stanev < traian.stanev at autodesk.com> wrote:
> Hi Mark,
> The libtool errors may be due to mismatched versions of your local
> automake version and the version in the MapGuide subversion. Did you try
> recreating libtool by running libtoolize, aclocal and automake/autoconf?
> Traian
> *From:* mark j [mailto: jansenbulk at gmail.com ]
> *Sent:* Wednesday, July 12, 2006 11:16 PM
> *To:* users
> *Subject:* [mapguide-users] more linux compile errors than you can shake a
> stick at
> Hello,
> I checked out revision 715 today and continued to try to complete the
> build on SuSE linux with gcc 4.1
> The build is still problematic in a number of areas, below is a list of
> some examples of the errors one encounters when compiling on linux. I assume
> that most of you are developing your apps on the Windows platform?
> - ACE libraries in the OEM do not compile without editing some of the
> source.
> - There are a number of tags that libtool doesn't support:
> libtool: unrecognized option `--tag=CXX'
> - The MdfModel compile in the common directory produces a number of errors
> like this one:
> GridSurfaceStyle.h:77: error: explicit instantiation of 'class
> std::auto_ptr<MdfModel::GridSurfaceStyle>' in namespace 'MdfModel' (which
> does not enclose namespace 'std')
> - A number of extra qualifications persist, for example:
> ./Services/PrintLayout.h:216: error: extra qualification 'MgPrintLayout::'
> on member 'LegendWidth'
> ./Services/PrintLayout.h:217: error: extra qualification 'MgPrintLayout::'
> on member 'LegendPadding'
> ./Services/PrintLayout.h:218: error: extra qualification 'MgPrintLayout::'
> on member 'HeaderHeight'
> ./Services/PrintLayout.h:219: error: extra qualification 'MgPrintLayout::'
> on member 'ScalebarHeight'
> ./Services/PrintLayout.h:220: error: extra qualification 'MgPrintLayout::'
> on member 'ScalebarPadding'
> ./Services/PrintLayout.h:221: error: extra qualification 'MgPrintLayout::'
> on member 'FooterHeight'
> ./Services/PrintLayout.h:222: error: extra qualification 'MgPrintLayout::'
> on member 'GroupIndent'
> (and in MgDev/Oem/geos-2.2.0/source/headers/geos/geos.h, as well as a
> dozen other header files)
> - The library libgeos.a is not compiled with the build_oem.sh script, so
> you have to enter that dir to compile, and then continue with the main
> mapguide make
> - libtool: unrecognized option `---mode=link'
>  in Makefile /home/mark/DEV_FORK/mapguide/MgDev/Web/src/JavaApi/Makefile
> This is by no means a complete list but hopefully provides an indication
> of the current state of the Makefiles in the revisions...
> Mark
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060714/ed6cfd1e/attachment.html
More information about the Mapguide-users mailing list
