[mapguide-users] Application hangs at startup AND compatibilty...
Robert Bray robert.bray at autodesk.com
Mon Jul 17 02:32:17 EDT 2006
Willem,
It's way late here and I really need to go to bed, but first a question and some quick comments.
Is the point data from a SHP file and if so does it have a PRJ file? If so can you please reply with the content of the PRJ file.
In general repositories between Open Source and Enterprise will be 100% compatiable. However Enterprise does use a different projection library which may not be recognizing the WKT string that represents the coordinate system. That is probably what is happening here. You could try deleting the PRJ file and manually specifying the coordinate system when you load the data file and see if that solves your problem.
More tomorrow...
Bob
	-----Original Message-----
	Sent: Mon 7/17/2006 1:49 AM
	Cc:
	Subject: FW: [mapguide-users] Application hangs at startup AND compatibilty...
	Could somebody please help my with this one?
	Willem
	-----Oorspronkelijk bericht-----
	Van: Willem Schwarte [mailto:willem at giskit.nl]
	Verzonden: vrijdag 14 juli 2006 10:09
	Aan: users at mapguide.osgeo.org
	Onderwerp: RE: [mapguide-users] Application hangs at startup AND
	compatibilty...
	Urgentie: Hoog
	Here an addition to my post below.
	I have now loaded the shapes again in the Enterprise version, but still
	no luck... I have added some screenshots to show the differences...
	First check the opensource_exte and enterprise_Ext. As you can see on
	the opensource version there are red dots. On the enterprise version
	they aren't there.
	Then I zoomed in to a location. Still no dots on the enterprise version.
	The settings for both versions are the same (see the studioSetting
	jpeg).
	How is this possible?
	Willem
	Ps. The loading on enterprise seems a lot more stable, but I am on an
	internal network, not tested over the internet.
	Verzonden: vrijdag 14 juli 2006 7:34
	compatibilty...
	Urgentie: Hoog
	Yes, I am getting complaints from customers about this issue too. I
	tried to compile the latest version, but got errors. I really need
	somebody to compile the latest version please....!
	I have installed the latest release of Mapguide Enterprise 2007 on a
	test server, and tried to access a site a couple of times. Till now I
	did NOT have the problem  of the site not loading. But then again, not
	all layers were showing.
	I copied the repositories from our open source version, but some layers
	are not showing at all, or are e.g points are not on the same place on
	the map. I have read something about an update coordinate system that
	could cause this problem. And I need to load all the shapes all over
	again.
	Is this correct? Could somebody verify this. Are the repositories from
	the opensource version and the enterprise version not compatible with
	each other??
	Willem Schwarte
	Van: Robert Leeman [mailto:rleeman at eitnl.com]
	Verzonden: donderdag 13 juli 2006 20:49
	Aan: MapGuide Users List
	Onderwerp: [mapguide-users] Application hangs at startup
	Hello All:
	I posted this issue to the list some time ago but am re-posting now to
	see
	if there has been any progress that I missed.
	The issue:  My MGOS apps frequently hang at startup (e.g. I will get a
	partial interface display but the application won't fully load).
	Usually,
	one or two browser refreshes will fix the problem and I'm good to go.
	Following my previous post I understood that this was a bug in the MGOS
	software and I had to live with it until it got fixed.  I haven't seen
	any
	recent discussion on the list about this, but it's a continuing issue
	for
	our users.  Typical client-side is various MS Windows flavours running
	IE or
	Firefox.
	I am wondering:
	1.  Has the issue been resolved in MGOS?
	2.  Or, has the issue been resolved in Autodesk MG Enterprise?
	I am serving Apache/PHP/AJAX apps from Windows Server 2003.  I believe I
	am
	running the most recent version of MGOS.
	Bob Leeman
	EIT (NL) Limited
	St. John's, NL
	Canada
	To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
	For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060716/dd61d345/attachment.bin
More information about the Mapguide-users mailing list
