[mapguide-users] App stops working after a few uses
Andy Morsell
amorsell at spatialgis.com
Mon Jul 24 14:50:18 EDT 2006
This is also in that older thread, but here are the contents of the batch
file that I use:
c:\pskill mgserver
c:\psservice stop "MapGuide Server"
c:\psservice start "MapGuide Server"
echo MapGuide restarted %date% %time% "<br>" >>
c:\inetpub\wwwroot\restart_MapGuide_log.htm
The psservice stop is a bit redundant, but I figured it couldn't
hurt........ The logging stuff is obviously optional.
Andy
-----Original Message-----
From: kenny at keniginc.com [mailto:kenny at keniginc.com]
Sent: Monday, July 24, 2006 11:47 AM
Subject: Re: [mapguide-users] App stops working after a few uses
This happens mostly when I attempt to load a few shp files using the studio
or when attemping to set the correct map extent; still struggling to get the
correct map view extent. It is mostly alright.
I suppose the process is performance intensive.
Please confirm that this will work. I am a bit too careful giving that this
server runs some other applications.
pskill MapGuide Server
For those of you who may have used this, please that this command will work,
and only for the mapguide server.
Thanks for the quick response
Quoting Andrew DeMerchant <andrew.demerchant at gemtec.ca>:
> If you want to force a service to stop, then try kill.exe (comes with
> the resource kit), or pskill.exe (from sysinternals.com)....that will
> let you stop a service that's not cooperating....though, in the end,
> you'll want to figure out what is causing the problem....
> kenny at keniginc.com wrote:
>> Not sure if anyone has had to deal with the current issue I am having.
>> I reboot our server at least 4 times a day.
>> I do this because after running the map app for about 3 times, it
>> stops loading and hangs.
>> When I try stopping and restarting service, service hangs on
>> "stopping" until I reboot the server.
>> I am very concerned about having to constantly reboot the server,
>> especially since we have other apps running on the server.
>> Is there a way to restart the service or the app without having to
>> reboot the server?
>> My boss is scheduled to do a demo of the os app 3:30pm today and I
>> have been testing it just to be sure all is well.
>> After my last test, now it is hung again.
>> Please assist.
>> Thanks
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-4GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
More information about the Mapguide-users
